Chicago/NW Indiana JDM D15B for Sale!
Whats up everyone I got my D15B swap for sale. The swap is complete. Now here's the scoop. I bought the motor at One 6(mark will vouch for me). The swap is in my 92 hatch and i will allow a test drive only if your serious about buying it. The swap of course is a JDM D15B, 94 Si Trans with a Exedy Stg. 1 Clutch and a ACT Pro-Lite 7.5 Flywheel, and a DC 4-2-1 Ceramic Header. The swap will not come with an intake. (its for a GSR and i needz it)
Asking 700.00 or best offer. No low balling!!!!!!!
Also for sale:
-SOHC Si Trans 150.00 (no grinds)
-D16Y8 IM 50.00
-DSM 14b TD05H Turbo 120.00(no shaft play)
-Virgin P28 100.00
-Obd2a Ex Wiring harness (cut at firewall but has all plugs) Make offer!
-Clean GSR Blades on bogus tires.Make offer
Any questions hit me up on myspace my name is chano garcia.
Modified by JDM_Frijoles at 1:16 PM 9/24/2007
Also for sale:
-D16Y8 IM 50.00
-Virgin P28 100.00
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dividedas1 »</TD></TR><TR><TD CLASS="quote">that sohc si trans is there any noise such as input shaft or anything like that. and roughly how many miles on it.</TD></TR></TABLE> Yeah, the throw-out bearing.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phengnhou »</TD></TR><TR><TD CLASS="quote">how much w/o the tranny, clutch, and flywheel?</TD></TR></TABLE> Sorry, can't part stufff out. Throw me an offer y0!
so the transmission was making noises then when ever you pressed the clutch in? Sorry im asking so much about it, its just i am on my 2nd transmission now that i have gotten screwed with a bad input shaft bearing. ya know that noise that is only there when the clutch is let out and engaged.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dividedas1 »</TD></TR><TR><TD CLASS="quote">so the transmission was making noises then when ever you pressed the clutch in? Sorry im asking so much about it, its just i am on my 2nd transmission now that i have gotten screwed with a bad input shaft bearing. ya know that noise that is only there when the clutch is let out and engaged.</TD></TR></TABLE> The noise goes away when you press the clutch pedal in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Frijoles »</TD></TR><TR><TD CLASS="quote"> The noise goes away when you press the clutch pedal in.</TD></TR></TABLE>
so your basically saying the input shaft bearing is all ff'd up and its not the throw out bearing. Cause throw out bearing make noises when the clutch pedal is pressed in.
for more junk transmissions. I'll buy the one thats on your swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dividedas1 »</TD></TR><TR><TD CLASS="quote"> I'll buy the one thats on your swap.
</TD></TR></TABLE> Only as long as you buy the whole swap
1 sLoW hAtCh
Northeast (Sales)
11
Feb 28, 2006 12:51 PM
