head
Ok fist i bought a 89 hatch dx with a d15 from some towing yard it is stock as expletive it was running good for a while then it snapt a timing belt i replaced it and i know i most likely bent a valve but i know some people with a **** load of heads laying around i want to use one after i get it rebuilt but the problem is i don't what heads i could use like what years what models any help would be appreciated.
Modified by spoolinhatch123 at 9:18 AM 9/24/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinhatch123 »</TD></TR><TR><TD CLASS="quote"> I don't what heads i could use like what years what models any help would be appreciated.</TD></TR></TABLE>
For starters...
There is a lot of info on H-T, but for swapping heads on D-series engines you can't beat D-series.org
http://www.d-series.org/forums...p?f=4
For starters...
first read this:
http://crx.honda-perf.org/arti....html
then this:
and then this:
https://honda-tech.com/zerothread?id=635580
then this:
and then this:
ill tell you right now u can take any head from 88-95 and put it on ur block. i no cuz i did(if i were you id try getting a vtec head off a d16z6 engine or and other vtec head that are sohc from those years.
Lo-Buck EF
10
Jun 7, 2004 10:56 AM
