Under drive pulley? bad or good?
Old Sep 24, 2007 | 05:31 AM
streetspeed607's Avatar
Default Edit** Lighten crank pulley good or bad??
My accord f22a6 has an light weight crank pulley and i was just curious to here peoples opinions on them. Is it going to hurt my engine at all? I thought that they would throw then engine balance off, but i talked to my friend who is a mechanic and he said that the motor is internally balanced and it wont affect it all.
your input is greatly appreciated
Thanks!
edit: i ment to say light weight crank pulley not under drive
Modified by streetspeed607 at 8:58 PM 9/24/2007
Old Sep 24, 2007 | 08:53 AM
Ross 2.0's Avatar
In a Junkyard near you.
A pulley is not going to affect much unless it hasn't been balanced (look for drill marks around the outer edges or somewhere on the side). It's not going to affect anything but the belt accessories at idle. They will turn slower and not work as well. While driving they should be fine. They aren't giving you very much advantage either.
Old Sep 24, 2007 | 12:49 PM
F23Coupe's Avatar
Default Re: (Captain Evil Monkey)
Read here: https://honda-tech.com/zerothread/2104833. You'll get a few HP across the range. It's not a bad mod. But I wouldn't recommend it if you're running the AEM's with a big stereo with amps in your car. I'd stick with UR's accessories pulleys then or get their stock sized crank pulley in addition. I have their older underdriven pullies and since I don't run a big stereo system (yet!), I don't have problems with losing audio power.
Old Sep 24, 2007 | 04:59 PM
BUMP EDITED
Old Sep 24, 2007 | 05:47 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (streetspeed607)
Its a great debate that people commonly get heated over. Yes the engine is internally balanced but the crank pulley is called a Harmonic balancer for a reason. I vote no (BTW my opinion is based on my knowledge of Automobiles and my 2 years of training in the Honda PACT program)
Old Sep 24, 2007 | 06:27 PM
Tyte-S's Avatar
Default Re: (cb7-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R &raquo;</TD></TR><TR><TD CLASS="quote">Its a great debate that people commonly get heated over. Yes the engine is internally balanced but the crank pulley is called a Harmonic balancer for a reason. I vote no (BTW my opinion is based on my knowledge of Automobiles and my 2 years of training in the Honda PACT program) </TD></TR></TABLE> I have to agree.
Old Sep 24, 2007 | 07:35 PM
So if i take it off and put on my lightend fly wheel this weekend, is that going to have the same negative effect??
Old Sep 25, 2007 | 04:06 AM
flatline911's Avatar
Cut the power steering belt while your at it that will free up power!
Old Sep 26, 2007 | 05:33 AM
Tyte-S's Avatar
Default Re: (flatline911)
[<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flatline911 &raquo;</TD></TR><TR><TD CLASS="quote">Cut the power steering belt while your at it that will free up power!</TD></TR></TABLE> FTW
nxr87
Dec 28, 2006 02:53 PM
j_wod2000
Mar 2, 2006 02:17 PM
Boosted2K
Jan 18, 2005 08:10 AM
japspecjohn
27
Nov 3, 2003 06:13 AM
RacerXintegra2k
Jan 21, 2003 03:09 PM
