Blower Motor Doesnt Want To Work!
* B A N N E D *
The blower motor wont start up and when I press the buttons for different settings the lights wont show up either. What can be the issue here? It seems like its a lack of a significant source of power. Anyone have any input? The car is a 98 Civic DX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simplegreenmachine »</TD></TR><TR><TD CLASS="quote">put a new blower motor in it?</TD></TR></TABLE>
Try a different blower motor and see if it turns on (if a different one does it just means the blower motor is burnt out...it happens).
If it only works on speed 4 it's the resistor pack.
If it doesn't work on any speed and a different one doesn't turn on (and work on any fan speed) then it's the wiring.
Most likely a bad ground, but possibly a bad power connection.
Test the voltage with a multi-meter at the plug, should be at or almost 12v.
If the lights on your climate control aren't going out - it's also possible (however unlikely) that the wires going to the climate control or damaged. I've never seen ALL of a climate control go out before..sometimes the switch breaks, sometimes the vent selector breaks..but I've never seen all the parts break...
Might wanna try a different climate control, see if that works. At least unplug it and it test the plug to see if you're getting 12v when the car's on or on ACC.
2007Accord4cyl
Mar 10, 2013 08:57 AM
90ED6LSV
Dec 31, 2012 06:42 AM
ef8ryder90
Oct 23, 2006 06:06 PM
Gant
28
Jan 9, 2005 03:52 PM
