ls vtec build ( what type of tranny and clutch)
hey guys this is my ls vtec build.
Block 97 b18b1
ARP rod bolts
ARP head studs
gloden egale ls vtec convirson
Hastings piston rings
type r timmingblet water pump and oil pump
pr3 pistions
Shotpeen LS rods
Balanced the entire rotating assembly
head b16a1
ported new valve seal
new valvetrain
The qustion i had was with this set up what type of tranny and clutch should i go with? i looking to daliy drive the motor but sometimes hit vtec.
thanks
Block 97 b18b1
ARP rod bolts
ARP head studs
pr3 pistions
Shotpeen LS rods
head b16a1
new valvetrain
thanks
I used an USDM ITR tranny and an exedy stage1 organic clutch w/ 9lb. flywheel.
Works very well for my app.
I do wish that I had a little taller 5th though. Cruising at 70mph @ 4k gets a little old...
I would try to get some newer cams. The early gen b16 cams suck.
for a stock tranny i think the 98spec itr tranny is a great tranny. i have it but the only thing i dont like is the wjhole highway rpm deal. but for an all motor setup the 4.7 final in the tranny is perfect.
