m24x is too much?
i've been thinking about some cams on my setup do you think that rocket motorsports m24x are too aggressive? my setup is as follows
b18b1
ls crank and rods shot peened and with arp rod bolts
p30's j-spec +25mm over
bottom end balanced
im going to run a b16 head
profab header
and a custom set of itb's from a cbr954 or a blox im with a 68mm throttle body.
car is a weekend warrior.
are the cams way too big?
b18b1
bottom end balanced
profab header
They may be way to big if youre not exactly sure what youre doing regarding lobe center placement. And i think Rocket usually only reco's the 24X for 2 liters or larger but i could be mistaken.
Not all "shops" are created equal. Anyway, did you bother reading what i wrote regarding engine size? The M24X are going to want to move alot of air that your 1.8 might not be able to provide.
If youre shop is so great, let THEM pick the cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiB16A »</TD></TR><TR><TD CLASS="quote">your in the bay area what "good" shop are you talking about?</TD></TR></TABLE>
RedZone performance in fremont.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EGB18C1 »</TD></TR><TR><TD CLASS="quote">Why wouldn't you just go with the m22xx?</TD></TR></TABLE>
i just ran across a good deal on the 24's but i was looking at the 22's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe »</TD></TR><TR><TD CLASS="quote">M22x VTEC lobe is similiar in size and function as JUN3. A little hotter than Pro1 VTEC.</TD></TR></TABLE>
fitable for a 81.5 lsv, with 11.7 compression?
fitable for a 81.5 lsv, with 11.7 compression?</TD></TR></TABLE>
Perfect for M22X. Will run really good if the rest of the setup is good (intake system, exhaust system, tuning).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacobolito »</TD></TR><TR><TD CLASS="quote">
Redzone tuned a customer of mine, M22x's in a 85x87...made 237 whp. They are a good shop yes, however I think you would like your power band better with the 22's over the 24's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">
Redzone tuned a customer of mine, M22x's in a 85x87...made 237 whp. They are a good shop yes, however I think you would like your power band better with the 22's over the 24's.</TD></TR></TABLE>
yeah i was leaning toward the 22's but just found a good deal on the 24's. but i will go with the 22's. thanks
I agree, the 22's will work better for your setup.....
I would like to try the 24's on the 85x87 engine soon!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">
Perfect for M22X. Will run really good if the rest of the setup is good (intake system, exhaust system, tuning).</TD></TR></TABLE>
Just curious why the M22x instead of the M22xx...wouldn't they be better suited for an LSV? I noticed lots of people like the pro 1 or 2 on their LSV's so I would have thought the M22xx with the larger primary lobes would better compliment that configuration.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone »</TD></TR><TR><TD CLASS="quote">
I would like to try the 24's on the 85x87 engine soon!</TD></TR></TABLE>
Redzone, San Jose
to the OP .. yea , m22's will for sure perform like no other for your setup .. i kno of a local guy around my area that has a strong 1.8L using the m22x
Redzone, San Jose
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe »</TD></TR><TR><TD CLASS="quote">Dang that's low power. Why you guys hyping this shiatt. I've seen dynos of street cars making 298.72whp on stock B20Z bottom end and ITR head and CTR cams.
Redzone, San Jose
Redzone, San Jose
civics4lyfe
Jun 17, 2013 09:26 PM
