pressurise coolant jounals
how do i pressurize my coolant jounals without taking ne thing apart, and what would i need to do it? i am getting oil in the coolant journals and dont know where to start looking for the problem. took off water pump and there was oil residue on it and it keeps overheating.
You check and see if the head or block was warped before putting the headgasket on? Having a bad or clogged radiator won't put oil in the coolant.
got motor rebuilt for turbo and never saw the engine when it was being worked on, im hoping they checked that, but what would i need to pressurize the system to see where the oil is coming from or where the clog is?
Pressurising the system won't tell where the clog is, if there is one. It will only tell you if you have a leak and where it is. Places (I got mine from snap-on) sell a tool that has an adapter that seals on the rad. cap hole. this adapter connects to a pump that you use to pump air into the system. Just make sure you don't go over what the cap is rated for. You will blow things up in the system if you do that.
SPORT INJECTION
Aug 25, 2003 12:15 PM
