push start YES! ....starter NO!!??
Old Sep 23, 2007 | 03:10 PM
lilsicsoul's Avatar
Default push start YES! ....starter NO!!??
i just finish my b16a swap into my 1990 4 door ef....because of running out of $$ i got stuck wit the ls tranny now i have a few problems...the starter dosent crank the motor..but wen i push the car it starts...is ther diff size starters? the car use to be lsv...99 bottom 2000 b16 head ls cable tranny but the starter that came in the swap wen bad and i used a old 91 teg starter help me!! please...b4 1
Old Sep 23, 2007 | 03:14 PM
The_Undertaker's Avatar
75.168.105.221
Default Re: push start YES! ....starter NO!!?? (lilsicsoul)
Check for connection of starter cable. It is a big wire on positive terminal side.
Old Sep 23, 2007 | 03:19 PM
lilsicsoul's Avatar
Default Re: push start YES! ....starter NO!!?? (1988hondacrxsiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 &raquo;</TD></TR><TR><TD CLASS="quote">Check for connection of starter cable. It is a big wire on positive terminal side.</TD></TR></TABLE> its all plug it makes the sound of it coming out but it dosent crank the motor.. is ther a size diff...of how can i tell what yer the starter is...?
Old Sep 23, 2007 | 03:27 PM
lilsicsoul's Avatar
help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Old Sep 23, 2007 | 03:42 PM
ef-hatchcrap's Avatar
Default Re: (lilsicsoul)
If you stick a screwdriver in between the terminals on the starter will it turn over? is yes then check all your fuses and your clutch switch on the clutch pedal its self
Old Sep 23, 2007 | 04:06 PM
slaminsam's Avatar
Tap it with a hammer and see if it cranks... If it does then get yourself a new one or have that one rebuilt.
Old Sep 23, 2007 | 04:47 PM
Angry's Avatar
I think hes saying the starter isnt making contact with the flywheel...
Old Sep 23, 2007 | 04:58 PM
usdmblackcivic's Avatar
i was having that same problem..and it was the starter was bad..
Old Sep 23, 2007 | 05:50 PM
Jonathan_ED3's Avatar
So, does your starter work?
Or, like somebody has already mentioned - is the problem that it's just not making contact with your flywheel?
DJMURILLLO
Sep 12, 2009 12:24 PM
The AW Alchemist
May 9, 2009 01:42 PM
shawnxme
Oct 7, 2007 01:20 AM
93si
12
Aug 3, 2003 08:55 PM
