help gas problem...
Old Sep 23, 2007 | 02:13 PM
EG-Tuner's Avatar
T1-Carlos
Default help gas problem...
new to the forums and was wondering if any can help me with this, did a ls vtec swap in my hatch and it runs fine but just recently noticed that gas is in my oil any idea's on what could be causing it?
thanks in advance
Old Sep 23, 2007 | 02:16 PM
stock_honda_coupe's Avatar
Default Re: help gas problem... (EG-Tuner)
Super rich conditions. Cranking but not starting.
Old Sep 23, 2007 | 02:50 PM
EG-Tuner's Avatar
T1-Carlos
Default Re: help gas problem... (stock_honda_coupe)
so do you think it could be just because the car is running rich? it has an upgraded fuel pump but as of right now i am using a stock p28 think that could be it?
Old Sep 23, 2007 | 02:55 PM
doood's Avatar
been there done that
why a stock p28?
tune that sucker
Old Sep 23, 2007 | 03:04 PM
EG-Tuner's Avatar
T1-Carlos
so do you think tuning it would solve it or just running a p72? kinda low on cash and cant tune right now i was also told maybe one of my injectors is stuck open or something like that (and that it may just be dumping fuel)
Old Sep 23, 2007 | 03:26 PM
exhaust blow a lot of black smoke?
Old Sep 23, 2007 | 03:29 PM
EG-Tuner's Avatar
T1-Carlos
yea at a high rpm throws a lil gray too
Old Sep 23, 2007 | 03:31 PM
definately rich conditions. I'd be worried about the headgasket too if its throwing gray or white smoke at high rpm.
Old Sep 23, 2007 | 03:39 PM
EG-Tuner's Avatar
T1-Carlos
what do you think could be causing it to do that? think its just tuning needed or something wrong with my fuel system? just trying to figure out some things to look at
Old Sep 23, 2007 | 03:55 PM
I would try to tune that computer and see what happens.
Old Sep 23, 2007 | 04:11 PM
EG-Tuner's Avatar
T1-Carlos
well just hooked up a air/fuel gauge and it shows im running rich but just a bar or 2 into it so since its not extremely rich would it be something else?
Old Sep 23, 2007 | 07:10 PM
EG-Tuner's Avatar
T1-Carlos
anyone else got anything? just looking for a couple of things to check, and jw if anyone else has had this problem
Old Sep 25, 2007 | 03:58 PM
doood's Avatar
unless you have a wideband o2 sensor and guage, i wouldnt trust the readings you got.
LsTegDriver
Aug 28, 2008 07:19 PM
jjr_99prelude
Apr 24, 2008 12:37 PM
Fastwhip
Aug 27, 2007 11:45 AM
91glassycrx
Feb 22, 2004 01:38 AM
