Has anybody had this happen to them?
Old Jun 17, 2002 | 09:37 PM
speck102's Avatar
Default Has anybody had this happen to them?
My 95' Accord started making a loud noise like I have an exhaust or something out of nowhere. So I checked the header, & the part where the pipe bolts on to the header, one bolt was missing, and the other two were completely loose. I don't think that is normal, it drove fine for several months before that with no problems. I wonder if someone had a custom header on there & didn't bolt it back on properly.
Old Jun 18, 2002 | 12:06 AM
H23 Power's Avatar
Default Re: Has anybody had this happen to them? (speck102)
so um, put a bolt in there and tighten the other ones?
its not really a big deal
Old Jun 18, 2002 | 04:40 AM
SOHCArchangel's Avatar
Default Re: Has anybody had this happen to them? (01GSR)
my kamikaze use to toss bolts all the time, so i went and got some 1.5" long stainless bolts with lock washers and nuts, and has been fine for the past 6 months
Old Jun 18, 2002 | 04:48 AM
Stew Pidasso's Avatar
I had it happen to me on my '90 Accord.I had to drive around for a day like that.It blew the gasket out between my header and A pipe.It sounded like a go-kart/airplane.
Old Jun 18, 2002 | 04:50 AM
Default Re: Has anybody had this happen to them? (Nitz5785)
yeah i used to burn them cheap-*** gaskets all the time before i started using copper o-ring collector gaskets (3 bolt) if you dont have that style of header like kamikaze (3 bolt triangle 2.5") get sheet of the mr gasket perma-seal? stuff and cut a new one, its hard, to cut but it will do the job
Old Jun 19, 2002 | 09:03 AM
speck102's Avatar
Default Re: Has anybody had this happen to them? (SOHCArchangel)
It isn't a big deal, I fixed it already, I just wanted to see if it was a common problem.
Old Jun 19, 2002 | 10:22 AM
4doorH22's Avatar
I think it's more common for those suckers to rust and seize than come loose.
Just1nK4ng
11
Aug 10, 2018 02:41 AM
guamie
Oct 3, 2007 04:35 AM
661rex89si
Jun 10, 2006 06:17 AM
BlueFang08
Mar 13, 2004 11:42 AM
geminis2k
Mar 3, 2003 02:45 PM
