9CivicHatch3's Stock Type R with BPI and Rage/Hytech Copy Makes 186WHP
Ginger Kid
Vtec should be set back about 400 to 500 rpm to smooth out the transistion.
Nice power
Nice power
USDM or JDM type-r ?
What ecu / ems ?
Any camgears ?
Don't trust sniffers too much. You should throw a wideband in the header etc
What ecu / ems ?
Any camgears ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">Don't trust sniffers too much. You should throw a wideband in the header etc </TD></TR></TABLE>
yeah i raised that point, but no one seemed to listen to me, must have been the brightly colored shorts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">USDM or JDM type-r ?
What ecu / ems ?
Any camgears ?
JDM r
Crome basetune for now
stock motor
What ecu / ems ?
Any camgears ?
</TD></TR></TABLE>JDM r
stock motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdMhEaD »</TD></TR><TR><TD CLASS="quote">
JDM r
stock motor</TD></TR></TABLE>
Sounds about right for a JDM R motor :-)
With some cam gears & tuning you could make more mid-range power. I doubt you will see much power past 186 in peak numbers.
JDM r
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 »</TD></TR><TR><TD CLASS="quote">
yeah i raised that point, but no one seemed to listen to me, must have been the brightly colored shorts</TD></TR></TABLE>
Yeah, it was def the shorts todd
i should just start wearing a suit everywhere, then people would think one of 2 things
1. hey, im gonna listen to the guy in the suit i bet he knows
2. why is that weirdo wearing a damn suit
With some cam gears & tuning you could make more mid-range power. I doubt you will see much power past 186 in peak numbers.</TD></TR></TABLE>
Sounds about right....more to come
Shooting for 190 with some air/fuel tuning and a little timing. Timing everywhere is very conservative right now since this is just a base tune...Timing below the curve will hopefully make up for alot of that vtec dip....like i said, more to come so stay tuned
If you have any suggestions on making 200 with stock cams and head port, shoot em my way...I am gonna need all I can get
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9civichatch3 »</TD></TR><TR><TD CLASS="quote">
yea keep that velocity stack ,it seemed to help
</TD></TR></TABLE>yea keep that velocity stack ,it seemed to help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c »</TD></TR><TR><TD CLASS="quote">Vtec should be set back about 400 to 500 rpm to smooth out the transistion.
Nice power
Oh, probably a good bit more than that.
Nice power
</TD></TR></TABLE>Oh, probably a good bit more than that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HcOiNvDiAc »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE> made 6whp with the stack..angled up with a fan blowing on it..
Ginger Kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK »</TD></TR><TR><TD CLASS="quote">post a copy of the crome basemap please if you dont mind...</TD></TR></TABLE>
I will post it up once I get my hands back on it....I will have to pull it off of his chip again....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pomansouth01 »</TD></TR><TR><TD CLASS="quote">
I will post it up once I get my hands back on it....I will have to pull it off of his chip again....</TD></TR></TABLE>
That would be cool. I really wanted to mainly check out the timing maps..
Ginger Kid
they are a stock b16 timing map reduced by 2 degrees across the board except for idle...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20beast978 »</TD></TR><TR><TD CLASS="quote">pretty decent build!!</TD></TR></TABLE> thanks, next will be valve springs and retainers and either S2S2 cams or Bisimoto custom cams
Ginger Kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9civichatch3 »</TD></TR><TR><TD CLASS="quote"> thanks, next will be valve springs and retainers and either S2S2 cams or Bisimoto custom cams</TD></TR></TABLE>
I wanna make 200 with the stock cam first though.....
I wanna make 200 with the stock cam first though.....</TD></TR></TABLE>
Unless your on a dynapack at churches I doubt thats gonna happen
I love the car, post pics son
