Knock when moving off and braking
Old Sep 23, 2007 | 07:14 AM
eg6madness's Avatar
Default Knock when moving off and braking
recently i have been hearing a slight knock when i move off and then again i hear it when i brake and come to a stop. I thought it was the Caliper moving so i jacked up the car and checked everything but nothing was loose.
while under there i held the wheel and started to rotate it and there it was. It sounded like it was coming from the differential and it is happening with both wheels.
Would it be the differential gone bad or just the part where the inboard joint's splines mesh with the diff?
any ideas?
***EDIT *** both axles have some play when i rotate them by hand b4 they mesh with the diff, when they mesh is them i hear the knock .( the knock comes fromo them meshing) is that the way it suppose to be?
Also everyone tells me the car has an LSD, it always leaves 2 solid lines, when i accelerate in a corner it pulls the car around with minimum understeer, if any at all. BUT then i jack up the car and spin the wheels with the car in gear one wheel spins in one direction and the other in the opposite, that doesnt sound LSD to me, am i correct? anyway else to tell? ***EDIT***
Modified by eg6madness at 11:26 AM 9/23/2007
Old Sep 23, 2007 | 11:47 AM
eg6madness's Avatar
Default Re: Knock when moving off and braking (eg6madness)
anyone
bigplayj17
Apr 13, 2007 09:31 AM
fujiwara takumi
Sep 1, 2006 09:51 AM
themilman
Jun 26, 2006 05:43 AM
Mykizism
Jan 30, 2004 09:07 PM
