Koyo radiator help
P# R1979 the koyo i got requires cutting the lip off the front crossmember so the lower fan mounting tabs and the drain plug will clear
Fn thing is 3 times as thick though as the oem
yes i got the one for 92-96 H22 and the mounts on the radiator go down to the ones on the cross memeber i just cant get them to slide over to go in. For now i took the rubber bushings out and just bolted it in and its fine since i dont drive the car.
The top and bottom mounts fit fine with my koyo in my BA8. It's so damn thick is my only problem with the stock crossmember. I bet it would clear perfect with a traction bar set-up. I cant wait to see Precisions
B18CYAAA
Sep 8, 2006 09:22 PM
lsvtec101
Nov 19, 2003 08:13 AM
