Suspension & Brakes Theory, alignment, spring rates....
Upper control arm sqeak
Old Sep 23, 2007 | 04:37 AM
B16B-NA's Avatar
Default Upper control arm sqeak
Tryed searching to see if i could find any info no luck!
I originally thought it was the tein super streets sqeaking but they seem fine no problems its deffently the upper control arms on both sides Has anyone had similar problems ?My car is a ek4 vti
Old Sep 23, 2007 | 08:52 AM
AMR Engineering's Avatar
Default Re: Upper control arm sqeak (B16B-NA)
I've had that happen, where the bushings sqeak. Inspect the bushings for wear first, and if everything is fine, then just lube em up.
FYI, just incase that is not it, it may be your machined top mount if you are using a machined top mount with your Tein SS. If your using the factory top mounts with it then your okay.
Old Sep 23, 2007 | 08:55 AM
.RTErnie's Avatar
Default Re: Upper control arm sqeak (AMR Engineering)
how you feeling this morning andy? ole washington took a beating yesterday
Old Sep 23, 2007 | 09:41 AM
B16B-NA's Avatar
Ok cheers gonna lube them tommoro ! Using the oem factory mounts
Old Sep 24, 2007 | 04:06 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
My UCA's were squeaking, also. It was because I did not preload the bushings correctly. You need to loosen the bolts that attach the UCA to the shock tower, and then tighten them at ride height.
Since you have an EK that should be easy as I believe you can access the bolts from the engine bay instead of having to get underneath the wheel well. So raise the front end off the ground, loosen those UCA bolts, lower the car back on the ground, and tighten the bolts back up at ride height.
Old Sep 24, 2007 | 07:42 AM
B16B-NA's Avatar
Default Re: (PatrickGSR94)
Thanks for the info will let you know how i get on
Old Sep 24, 2007 | 09:52 AM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
Since you have an EK that should be easy as I believe you can access the bolts from the engine bay instead of having to get underneath the wheel well. So raise the front end off the ground, loosen those UCA bolts, lower the car back on the ground, and tighten the bolts back up at ride height.</TD></TR></TABLE>
I have the same issue I think. When going over say a speed bump, I get this creaking noise when hitting the top of the bump at a slow speed.
How do you even get to the UCA when the car is lowered back down to the ground? I can't fit my arm in there with the wheel on.
Old Sep 24, 2007 | 01:09 PM
Community Builder
Default Re: (CAN97SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CAN97SH &raquo;</TD></TR><TR><TD CLASS="quote">
How do you even get to the UCA when the car is lowered back down to the ground? I can't fit my arm in there with the wheel on.</TD></TR></TABLE>
On EK Civics, the UCA bolts on the shock tower are on each side of the shock tower, and accessible from the engine bay.
For EG's and DC's you need to have the shock/spring removed, and then you have to raise the suspension with a floor jack to about where it would be at ride height, and then tighten the bolts.
Old Sep 24, 2007 | 01:19 PM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
For EG's and DC's you need to have the shock/spring removed, and then you have to raise the suspension with a floor jack to about where it would be at ride height, and then tighten the bolts.</TD></TR></TABLE>
Ahh that makes sense. I was wondering how skinny your guys' arms were
Old Sep 25, 2007 | 09:53 AM
B16B-NA's Avatar
Default Re: (B16B-NA)
Well tryed this route this afternoon ,seems worse now creaking over small bumps proper downer Any reason why its become worse now??
alexdc03
Apr 26, 2011 07:36 AM
Space Cadet
Suspension & Brakes
Oct 29, 2010 04:55 PM
ComeOnKip
Jun 1, 2009 05:57 PM
Mr. JDM-GSR
May 6, 2004 06:30 PM
92-h23a1
Jun 6, 2003 09:29 PM
