Suspension & Brakes Theory, alignment, spring rates....
Replaced tie rod boot, but what's this weird hose connecting the two?
Old Sep 23, 2007 | 12:32 AM
erikiksaz1's Avatar
Default Replaced tie rod boot, but what's this weird hose connecting the two?
It's number 2 in this picture. Is it necessary to connect it to the tie rod boots? It is a MAJOR pita, as the nipple on the tie rod boot is soft, and the hose rubber is relatively hard.
Old Sep 23, 2007 | 08:05 PM
Targa250R's Avatar
be professional
Default Re: Replaced tie rod boot, but what's this weird hose connecting the two? (erikiksaz1)
It's obviously there to help equalize the air pressure in the boots more quickly as one compresses and the other extends.
Old Sep 23, 2007 | 09:42 PM
Guam_CiviC619's Avatar
Default Re: Replaced tie rod boot, but what's this weird hose connecting the two? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">It's obviously there to help equalize the air pressure in the boots more quickly as one compresses and the other extends.</TD></TR></TABLE>
Ditto and without it you are prone to sucking in nasties into the freshly replaced boot every time you rotate that steering wheel. Try adding a dab of oil in the hose.
Old Sep 23, 2007 | 11:43 PM
erikiksaz1's Avatar
Default Re: Replaced tie rod boot, but what's this weird hose connecting the two? (Guam_CiviC619)
Hrmm, I found that the hose was disconnected from the boot that was torn. Maybe some funk got into there.
Either way, I don't know why they made the hose so bloody short. I wonder if using replacement silicone hoses will collapse under the heat, if there is any in that area.
1drivinmofo
Feb 12, 2025 09:15 PM
AMS_
22
Jan 15, 2013 05:13 PM
mxl360
Aug 22, 2007 11:58 AM
e jay one
Jan 24, 2007 10:02 AM
Rywire
Sep 25, 2004 02:44 PM
