ignition problem....help
Old Sep 23, 2007 | 12:30 AM
efnoobie's Avatar
Default ignition problem....help
ok..heres the thing... i just bought this hatch w/ messed up wiring egined harness cut up and ecu harness..now i swapped out the messed up one to uncut one...ok the problem before i even swap it out the car starts i just turn the key to on and press the clutch so practically when the key is on the On then i just press the clutch it starts..right..isn't usually normal turn on the car is. press the clutch then turn the ignition.. but for some reason its still the same after i swap the wire harness.. i dnt know whats goin on.. help out...about the ignition.
Old Sep 23, 2007 | 12:52 AM
Hanmin's Avatar
Works both ways for me, I can either hold the clutch and then turn the key all the way or turn the key all the way and then press on the clutch.
Old Sep 23, 2007 | 01:08 AM
efnoobie's Avatar
Default Re: (Hanmin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin &raquo;</TD></TR><TR><TD CLASS="quote">Works both ways for me, I can either hold the clutch and then turn the key all the way or turn the key all the way and then press on the clutch.</TD></TR></TABLE>
yea thats the normal way but mine..i just leavethe key to ON then press the clutch its starts... i dnt need to turn the key all the way..it starts either way.
Old Sep 23, 2007 | 05:18 AM
dr.carvorkian's Avatar
Default Re: ignition problem....help (efnoobie)
You need to get a hold of a wiring diagram for the ignition system. for some reason your signal wire to your starter is getting power when the clutch is depressed, so it's cranking. It'll be a simple fix with the diagram.... without it you won't have any fun. I wouldn't even mess with it until you know where and how things are supposed to go. You can probably go to any shop and offer to give them 5 or 10 bucks for a print out of the diagram.
Old Sep 23, 2007 | 12:36 PM
efnoobie's Avatar
Default Re: ignition problem....help (dr.carvorkian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr.carvorkian &raquo;</TD></TR><TR><TD CLASS="quote">You need to get a hold of a wiring diagram for the ignition system. for some reason your signal wire to your starter is getting power when the clutch is depressed, so it's cranking. It'll be a simple fix with the diagram.... without it you won't have any fun. I wouldn't even mess with it until you know where and how things are supposed to go. You can probably go to any shop and offer to give them 5 or 10 bucks for a print out of the diagram.</TD></TR></TABLE>
nice ill do that..before i do something else..
Old Sep 23, 2007 | 06:19 PM
efnoobie's Avatar
up...agian... havent got a chance to go to the shop and ****.. ne one else got any ideas
Old Sep 23, 2007 | 09:03 PM
efnoobie's Avatar
up can anybody help me out?
Old Sep 24, 2007 | 01:13 PM
efnoobie's Avatar
up for today
Tomcat95
Aug 21, 2016 03:43 AM
curioso
Sep 8, 2007 03:54 PM
pistol_p
Mar 7, 2007 12:20 PM
99cpevtec
Jul 15, 2005 02:27 PM
