car won't start
i knoww this has been covered a million times, but this sux.
b16 obd1, it cranks but thats about it. doesn't start.
fuel pump pumps
took off the top bolt off of the bolt on the fuel filter and squarts. checked the line on the opposite side of the fpr and is getting fuel.
spark plugs are new, after i cranked i took out the plug and smelled like fuel a little bit but not to much noticable. injectors>?
checked for spark in spark for # 4 cylinder, saw a spark
I checked to hear the clicking sound under the dash driver side for the main relay, and i'm hearing clicks dont' know if it can be something else.
put it to tdc and tried to crank didin't work.
checked fuses dash and hood....
This started when i put a new intake manifold gasket. it was a high idle and white smoke was coming out, overtorqued
got a torque wrench and a hondata gasket and now it doesn't start. everythings pluged in.
If it makes a diff. the mph goes up to 20 when i try to crank.
anyone have any other ideas>?
wires look like this
fuel pump pumps
hondabro1988
Jul 31, 2012 02:55 PM
