Tighter v2p clearance?
Old Sep 22, 2007 | 06:44 PM
all-mtr-teg's Avatar
Default Tighter v2p clearance?
I know some builders have built motors with tighter V2P clearances, but i want a bit more CR around 11.3-11.5 Will i be okay if i get a thinner H.G. and run IN 0.04" and EX 0.06" V2P clearances on a D.D. Also, what is the thickness of an OEM H.G. i've seen some compression calculators say .026" and some 0.029"
Old Sep 23, 2007 | 05:13 AM
Furyof4's Avatar
Default Re: Tighter v2p clearance? (all-mtr-teg)
That's about as tight as you want to go. Why do you want more compression? 11.5 will work great on pump gas.
Modified by Furyof4 at 9:36 AM 9/23/2007
Old Sep 23, 2007 | 08:23 AM
Default Re: Tighter v2p clearance? (Furyof4)
Yeah, I want around 11.3-11.5 CR, right now since im running a 0.08" H.G. according to clubcivicquebec compression calculator im at aroung 10.5 CR. I used such a thick H.G. cause head and block were milled and decked a total of .021" and pistons came out of the block deck around 0.008" W/ stock H.G. i had 0.01" IN and 0.03" EX V2P clearance, so i used a 0.08" to achieve 0.06" IN and 0.08" EX V2P clearances.
o0o_tylor_o0o
Dec 7, 2010 07:03 PM
DeadVet
Feb 9, 2005 12:34 PM
YOSOLO CRX
13
Nov 13, 2003 08:53 PM
ViZ
Mar 24, 2003 09:03 AM
AEM R&D
Mar 17, 2003 03:06 PM
