wheel studs
Old Sep 22, 2007 | 06:32 PM
TurboEK9Coupe's Avatar
Default wheel studs
Does anyone have the part number for the ARP extended wheel studs for a 2000 civic ex? And how much longer are they then the factory ones?
Old Sep 22, 2007 | 07:12 PM
BlueIntegraBoy's Avatar
Default Re: wheel studs (TurboEK9Coupe)
Part Number: 100-7711
1" longer
Old Sep 25, 2007 | 09:46 AM
Default Re: wheel studs (BlueIntegraBoy)
Has anyone tried to put the studs in with out replacing the wheel bearing? Try to save the wheel bearing when you press out the hub to put the extended studs in. The bearings from napa are about $80 a piece and im tring not to spen that much now. Thanks
743power
182
May 19, 2017 07:30 AM
B_Swapped93
Mar 29, 2014 08:44 PM
SlowB16
Jun 11, 2008 07:00 AM
Tyson
22
Jul 13, 2002 03:45 PM
