ok i need u guys opinion.....b series or h series
Old Sep 22, 2007 | 05:36 PM
EJ8CIVIC's Avatar
Default ok i need u guys opinion.....b series or h series
i know this but posted back in da day now its my turn
ok iv been putn together a b16a2 and this is wat im lacking these items
tranny, dizzy, axles, clutch kit nisc nuts/bolts
i got the oportunity to trade wat i got for a COMPLETE H22a4 whick is lacking
mounts, ecu, axles, and the shifter plate is in the mail(da guy jus order the shifter plate)
soo lmk watu guys wud do
Old Sep 22, 2007 | 05:38 PM
EJ1chevelle's Avatar
Default Re: ok i need u guys opinion.....b series or h series (EJ8CIVIC)
B FTW! like it better than a h... smoother imo. tranny is waaaay smoother.
Old Sep 22, 2007 | 05:44 PM
H22Ej1's Avatar
Shenanigans
Default Re: ok i need u guys opinion.....b series or h series (93egB16A)
get the h but keep ur bseries trans and do an h2b
if u do trade for it make sure the motor is in good working order and not a busted up pos
Old Sep 22, 2007 | 05:46 PM
Default Re: ok i need u guys opinion.....b series or h series (H22Ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Ej1 &raquo;</TD></TR><TR><TD CLASS="quote">get the h but keep ur bseries trans and do an h2b
if u do trade for it make sure the motor is in good working order and not a busted up pos</TD></TR></TABLE>
he doesnt have the b series trans
Old Sep 22, 2007 | 05:49 PM
EJ8CIVIC's Avatar
yea i dont got the tranny
me and this guy bout from each other couple times....
as far wat he told me its all 2gether tranny still boltd up and head still boltd to block....
soo far i have a friend said thathe wud do the trade and another friend thatdone a hseries swap in civic he said he wudnt trade......
Old Sep 22, 2007 | 05:54 PM
Boost_V's Avatar
you looking to keep either naturally aspirated for awhile?
Old Sep 22, 2007 | 05:57 PM
EJ8CIVIC's Avatar
Default Re: ok i need u guys opinion.....b series or h series (Boost_V)
well if ikeep the h22 im going to keep it stock
and if i keep piecing my b16 2gether im jus going to do itbs
Old Sep 22, 2007 | 06:29 PM
EJ8CIVIC's Avatar
jus found out the h22 has less then 60k on it
Old Sep 22, 2007 | 06:53 PM
Boost_V's Avatar
I'd go H22.
Old Sep 22, 2007 | 06:54 PM
Doostur's Avatar
B 4 Life.
Old Sep 22, 2007 | 07:25 PM
EJ8CIVIC's Avatar
Default Re: (Doostur)
and if i do the trade can i still run a/c wit the h22??????????
Old Sep 22, 2007 | 07:48 PM
Syndacate's Avatar
Don't be a tool, get an H.
Old Sep 22, 2007 | 07:52 PM
Doostur's Avatar
Default Re: (EJ8CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">and if i do the trade can i still run a/c wit the h22??????????</TD></TR></TABLE>
AC is overrated, but I sure do miss it
Old Sep 22, 2007 | 08:00 PM
EJ8CIVIC's Avatar
well im goin to keep a/c
if that calls for me keepn my b16
and plus my wife drivers my car here and there
Old Sep 22, 2007 | 08:15 PM
Boost_V's Avatar
Whether you choose the B or the H really shouldn't determine if you could still have a/c or not. Or at least it shouldn't.....
Old Sep 22, 2007 | 08:21 PM
Syndacate's Avatar
Default Re: (Boost_V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost_V &raquo;</TD></TR><TR><TD CLASS="quote">Whether you choose the B or the H really shouldn't determine if you could still have a/c or not. Or at least it shouldn't.....</TD></TR></TABLE>
I'm pretty sure you need a custom bracket to run AC in an H swapped civic.
Old Sep 22, 2007 | 09:36 PM
EJ8_TCAN's Avatar
h swap is good but your axle will get fucked up quick... id go for b series. but with the H swap, you will make good power
Old Sep 23, 2007 | 09:10 AM
Syndacate's Avatar
Default Re: (EJ8_TCAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8_TCAN &raquo;</TD></TR><TR><TD CLASS="quote">h swap is good but your axle will get fucked up quick... id go for b series. but with the H swap, you will make good power</TD></TR></TABLE>
With the older customized mounts, yes, if you buy regular AVID H series mounts or utilize an H2B setup they won't be.
Old Sep 23, 2007 | 09:27 AM
sleepyH22's Avatar
i am puttin a h22 in a 92 vx hatch right now and the way i look at it is this....
a si or gsr swap vs a h22 swap money wise is pretty close IMO... BUT, 1.6l engine with 160hp or a 2.2l w/190-210hp...and yes i know the h22 is more work and believe me i do know..i am doing it now but i feel like the lil more work is worth the extra power and for me i wont be happy with a torqueless 1.6-8.... &lt;--- im referring to leaving the engines basically stock. if you are b00stin just stay b series...but n/a h22 civic is what im doing.
Old Sep 23, 2007 | 09:46 AM
StreetRacinThug's Avatar
B Series is overrated, H22 is so much worth it.
The only thing you need to worry about is mounts and axles, shift kit. Everything else is the same, I would rather run low 14s all day than low 15s with a b16!
Old Sep 23, 2007 | 11:38 AM
hard charging 929's Avatar
Default Re: (StreetRacinThug)
Both the B and H are good motors. Depends on what you ultimately want out of the vehicle.
I'd rock the H2B. Tight tranny with lots of ontap power and torque, easier installation than a full H swap.
Old Sep 23, 2007 | 11:50 AM
cwlsvtec's Avatar
Default Re: (agoldenau)
go with the b series
Old Sep 23, 2007 | 01:43 PM
EJ8CIVIC's Avatar
Default Re: (cwlsvtec)
i think im stickin with my b16
i was think with the cash i wud spend on putn the h22 in my car i cud have the cash and have my b16 done....and plus its my only car and i dont fill like cuting my engine bat mount thingy and drillin a hole for the cables..
and i already have my itbs half way done
Old Sep 23, 2007 | 01:47 PM
Libertariat's Avatar
Ek Forever y0!
Compromise. Do an h2b setup.
h22 &gt; itb'd b16.
You'll for a lot faster for less with the h22 with an n/a setup.
Old Sep 23, 2007 | 01:58 PM
dion91Ls's Avatar
my buddy had a h22 in his EG and the ride was smooth and it had hella pull
dont know which h22 but it was quick
