IACV prob?
I saw the writeup for engine idle probs. and being that i have a Y8 im lacking the FITV so i decided to contiue with the trouble shooting. So i plugged the IACV hole the TB with my finger and car almost died. Does this mean its going out? cause the write-up doen't exactly make sense. Thanks guys.
here's the writeup.
http://www.ef-honda.com/ben/Badidle.php
here's the writeup.
As long as your y8 has a manual tranny, to check it you should unplug the iac valve and pay attention to how the engine idles. If your engine's idle speed decreases or the engine cuts off all together, it is working properly. Civics with auto trannys or all civics with y7 engines will increase in idle speed in this test. Hope this helps!
damn it's running like poo.
