Rear Wiper Removal
Old Sep 22, 2007 | 05:05 PM
jayden1295's Avatar
Default HElp...
i have a 91 crx.. does anybody know how to remove the rear wiper arm... thanx
Old Sep 22, 2007 | 05:49 PM
Mr.Death's Avatar
Default Re: HElp... (jayden1295)
Easy. At the base of the wiper there is a cap covering the 12mil bolt. Remove it then loosen the 12 mil and pull the wiper off. Easy breezy as 123zy!!
Old Sep 22, 2007 | 07:39 PM
STREETWERKZ's Avatar
Default Re: HElp... (Mr.Death)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Death &raquo;</TD></TR><TR><TD CLASS="quote">Easy. At the base of the wiper there is a cap covering the 12mil bolt. Remove it then loosen the 12 mil and pull the wiper off. Easy breezy as 123zy!!</TD></TR></TABLE>
if you want to take it further, take the plastic off from under the hatch.
then remove the 3 10mm bolts holding the motor and unplug the wiring.
after that, go back to the top and remove the 22mm (??) nut that is holding the arm to the body from the top.
it'll drop down, removed.
if you wish to plug the hole, there is a rubber grommet in the engine bay shaped similar to the remaining hole. either remove it from the bay, or buy a new one from honda.
Old Sep 22, 2007 | 08:29 PM
jayden1295's Avatar
Default Re: HElp... (STREETWERKZ)
thanx guys..
93beccalx
17
May 2, 2008 03:59 PM
egeeb16
10
Jun 28, 2007 01:40 PM
aVstAr
Apr 18, 2006 07:33 AM
Dogginator
Sep 27, 2005 04:56 PM
FakeJDMEF8
Sep 26, 2004 07:39 PM
