NEED HELP! 95 integ radio help!
Old Sep 22, 2007 | 03:54 PM
uspeedwalt's Avatar
Default NEED HELP! 95 integ radio help!
1995 Acura Integra 2 door
So i just installed 4 6.5 pioneer speakers. First of all the radio used to work, it isnt really installed properly in the first place. I can take out the whole unit and in like nothing. So i go to install these speakers today...they worked when i checked them, but when i slid the radio into the sleeve something shorted.
So now my radio doesnt get power, nor does my clock! Could anyone please direct me towards the light.
A) Checked all fuses in the car, good.
B) Checked fuse on the radio itself, good.
Any help would be great
Old Sep 22, 2007 | 04:23 PM
suspendedHatch's Avatar
Default Re: NEED HELP! 95 integ radio help! (uspeedwalt)
When a fuse blows, it blows for a reason. Simply replacing the fuse does not solve the problem. Find what "shorted" and wire it/insulate it properly.
Checking a fuse visually can tell you if it's bad, but it can't confirm that it's good. It needs to be verified with a multimeter.
You didn't check the fuses under the hood. The 7.5a backup fuse is most likely the one you're looking for. Fix the problem first, then replace the fuse with the same rating.
Old Sep 23, 2007 | 08:00 AM
fcm's Avatar
fcm
Old Fart
I agree with the above, it's the backup fuse, [clock also not working] that is the yellow wire into the HU and white with yellow or blue tracer in cars radio harness.
Also what is the make and model of the HU, what size is the HUs fuse?
If the HU is not mounted properly, you will run into problems like skipping and premature misalignment of the lens.
Was a kit and adapter harness used to install the HU? 94
Old Sep 23, 2007 | 01:44 PM
uspeedwalt's Avatar
thanks alot for the help everyone, i taped off everything in there interior. Looked under the hood at the fuses and sure nuff the BACKUP fuse was blown.
thanks alot!
now i can actually listen to music
Kenneth.Honda94
Audio / Security / Video
Sep 16, 2014 10:04 AM
omarisramo
Feb 28, 2008 05:19 AM
Synthesis
Jun 5, 2004 07:55 PM
allmotorej8
Apr 1, 2004 07:06 PM
crx_kid
Oct 15, 2003 11:08 PM
