Swapped cams on my SV650
Old Sep 22, 2007 | 11:20 AM
rdblckSV650S's Avatar
Default Swapped cams on my SV650
I have read about the cam swap for SVs for a while now but haven't had the ***** to open up my motor. I picked up a used set of 1st gen intake cams for $90 and decided to go for it. Install was super easy with the walkthrough from BARF and it only took me 4 leisurely hours. Power is improved. Nothing earth shattering. But it did power wheelie in second gear during the test ride, and it wouldn't even power wheelie in 1st before. Top end is much stronger. Peter lombardi took pictures for me and lent a hand. Here they are.
all photos thanks to peter lombardi http://www.peterlombardi.com
Old Sep 22, 2007 | 11:27 AM
iLude's Avatar
Default Re: Swapped cams on my SV650 (rdblckSV650S)
Can you tell me more about this cam swap? What's so different about the first gen intake cams?
I've always loved your SV Good chance I'll have one as my next bike
Old Sep 22, 2007 | 11:30 AM
marmaladedad's Avatar
Methinks you've got some dirt on your chin.
Great pictures. Linky to the BARF writeup?
<-- too lazy to search on BARF
Old Sep 22, 2007 | 11:42 AM
Default Re: (marmaladedad)
Pfff, you talkin about my ghoater?
There was a good writeup on Svrider with pictures, but the pictures are gone after the server move.
Here's the BARF one
http://www.bayarearidersforum....54847
On the first gen SVs they swap both cams and gain quite a bit more power. On the 2nd gens you swap the 1st gen intake with the exhaust side because it has more lift than the exhaust cams. This gets you a little more power without sacrificing reliability, or much else.
Old Sep 22, 2007 | 11:51 AM
.RJ's Avatar
.RJ
Default Re: (rdblckSV650S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdblckSV650S &raquo;</TD></TR><TR><TD CLASS="quote">On the first gen SVs they swap both cams</TD></TR></TABLE>
Whats swapped in?
Old Sep 22, 2007 | 11:56 AM
Truly, the SV is the frankenstein of the motorcyle world.
Chris y0!'s Avatar
Default Re: (.RJ)
AWW look at those cute little cams
Old Sep 22, 2007 | 12:04 PM
Default Re: (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Whats swapped in?</TD></TR></TABLE>
i think they move thier intake cams to the exhaust side and swap in 2nd gen intake cams for the intake side. That swap makes nearly 4hp throughout the entire rpm range. But that puts a 1st gen on par with a 2nd gen that has a cam swap. So i'm doin alright.
Old Sep 22, 2007 | 01:15 PM
sup gurl's Avatar
Sorry if I over looked, but has anyone dyno'd these cams versus stock?
Power wheelie?! On an SV650?!one!!1 UNHEARD OF!
Very niceee
Old Sep 22, 2007 | 01:18 PM
EngineNoO9's Avatar
Default Re: (sup gurl)
on BARF there were several dynos. I really liked the 1st gen dyno with multiple mods
Stage 0: 65.1 HP @ 9000 RPM, 41.1 ft-lbs, 14:1. Renegade slip-on exhaust, 15 pilot jets, 137.5 main jets, 1 shim on needle.
Stage 1: 69.9 HP @ 9300 RPM, 42.75 ft-lbs, 15:1. M4 full exhaust, 17.5 pilot jets, 152.5 main jets, 2 shims on needle, desnorkled airbox.
Stage 2: 76.6 HP @ 9700 RPM, 44.88 ft-lbs, 12:1. Cam swap, M4 full exhaust, 17.5 pilot jets, 157.5 main jets, 2 shims on needle, desnorkled airbox.
a/f for stage II
Old Sep 22, 2007 | 01:31 PM
b00st Junkie's Avatar
TOASTYYY!!
Default Re: (EngineNoO9)
Wow everytime I see one of these it just makes me want one that much more. Im seriously considering this as my next bike.
Old Sep 22, 2007 | 01:48 PM
sporkcrx's Avatar
Default Re: (b00st Junkie)
wow, big power difference just with cams
Old Sep 22, 2007 | 02:02 PM
Default Re: (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">wow, big power difference just with cams</TD></TR></TABLE>
that's on a 1st gen though and they swap both cams. But, the amount of power a 2nd gen makes with its cam swap is very similar. Especially with mods.
Does anyone know if you can order headers from m4 to complete a system if you've got a slipon from them?
Old Sep 22, 2007 | 02:36 PM
Quiks66's Avatar
Any issues with the stock valve springs? I'm assuming the cams you swapped in have more lift, but what about duration?
Old Sep 22, 2007 | 02:41 PM
Default Re: (Quiks66)
I'm not sure about duration, but the lift is more, but it's nothing bigger than what the bike was meant to take. Lots of racers have done the cam swap without any valvetrain issues.
Old Sep 23, 2007 | 09:44 AM
Quiks66's Avatar
Good to know.
for being brave enough to open the motor up
Old Sep 23, 2007 | 10:55 AM
swappedcx's Avatar
I love your bike
After talking to you and getting insurance quotes im on the hunt for a sv
Old Sep 23, 2007 | 03:27 PM
Default Re: (swappedcx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swappedcx &raquo;</TD></TR><TR><TD CLASS="quote">I love your bike
After talking to you and getting insurance quotes im on the hunt for a sv </TD></TR></TABLE>
muahahaha, another convert! Time to pick up my commission check from suzuki!
Old Sep 23, 2007 | 03:32 PM
.Ash's Avatar
15 minutes and we could save you 15% or more! (shameless plug)
Old Sep 24, 2007 | 08:19 AM
rol1in0n20s's Avatar
Default Re: (.Ash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Ash &raquo;</TD></TR><TR><TD CLASS="quote">(shameless plug)</TD></TR></TABLE>
Do you work for them??
Old Sep 24, 2007 | 09:02 AM
ScareyH22A's Avatar
Honda-Tech Gold Member
Community Builder
Default Re: (rol1in0n20s)
The question is....
Can you trackstand it?
Old Sep 24, 2007 | 09:27 AM
Default Re: (ScareyH22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScareyH22A &raquo;</TD></TR><TR><TD CLASS="quote">The question is....
Can you trackstand it? </TD></TR></TABLE>
like this kind of trackstand?
Old Sep 24, 2007 | 11:20 AM
svrider's Avatar
did you check the valve clearance after the swap?
Old Sep 24, 2007 | 12:50 PM
Default Re: (svrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by svrider &raquo;</TD></TR><TR><TD CLASS="quote">did you check the valve clearance after the swap? </TD></TR></TABLE>
nope
Old Sep 24, 2007 | 03:49 PM
that one guy's Avatar
looks great. always love watchin your bike progress. couple questions tho, 1. how does this effect your gas mileage? 2. why is it in all of your pics of installs you are never dirty or greasy?
