best sc61 to use for 450-550 gsr
i have a gsr im building to a 2.0 l looking to make 420-450whp using the least amount of boost lmk what turbo would be best from the sc61 trims etc.
Well, just to keep this on the first page, the SC61 has better wheels (both sides), and a 360 degree thrust bearing. The turbine housing is also made by Precision, and is said to be a slightly better flowing unit than the t3 housing, even though they have the same A/R.
Hopefully someone with some good, first hand knowledge will comment!
yeah the sc6152e comes with a stage 5 wheel. used this turbo on a fully built LS motor 85mm and it made 403whp on 18psi... i plan to use this same turbo on my built gsr that will be done very soon.... its a great turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tjabo »</TD></TR><TR><TD CLASS="quote">Just a stupid question unrelated to the thread, but wth do you do with 600+ hp in a FWD car?
race it at the track.
</TD></TR></TABLE>race it at the track.
get slicks.... and run 10's
yes that was a stupid question
</TD></TR></TABLE>get slicks.... and run 10's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt »</TD></TR><TR><TD CLASS="quote">
yes that was a stupid question</TD></TR></TABLE>
Or if you are a really good driver and have your car set up right run 9's
I haven't been around any really high power FWD cars, and it's just hard for me to imagine hooking up the front tires with that much power and the adverse weight transfer. Interesting to know it can really be done!
Sorry for the off track!
sc61e better than sc61s and im not sure which one to buy a sc61
with a 3inch inlet
what model 6152 6169 6179
turbine .63ar or .82ar please somone lmk the best sc61 to buy
with a 3inch inlet
I am curious about the exhaust side too, but I was told that the "S" cover was worth about 50 HP over the "E" cover, and there wasn't a significant down side to it (?). The S cover does look bigger, but it really doesn't extend outside of the diameter of the heads of the bolts that hold the E cover on.
