Will a B16a gen2 (92 integ) fit in my 88 Crx si?
Any problems. There are for example can not use the stock mounts, can not have stock linkage, can not run same ecu, can not run same axles, can not have front mount in the way for header, can not have same harness if from obd1 engine. Here is link it will help you out for sure
https://honda-tech.com/zerothread/1508680 Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Allday07 »</TD></TR><TR><TD CLASS="quote">the search button is red for a reason
And there is a FAQ section at the top of the page for a reason as well.
</TD></TR></TABLE>And there is a FAQ section at the top of the page for a reason as well.
Knightrider
Dec 27, 2001 05:36 AM
