DC5 to EM2 dash conversion
does anyone know if the rsx dash will bolt into en EM2. i looked it over vaguely comparing and dimentions and mounting points look very similar. anyone have links or info on this? thanks guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rick1574 »</TD></TR><TR><TD CLASS="quote">how about a dc5 gauge cluster in an em2?</TD></TR></TABLE>
its not a direct fit, you need a custom bezel
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rick1574 »</TD></TR><TR><TD CLASS="quote">does anyone have a link to a DIY?
i've been searching...can't seem to find one.</TD></TR></TABLE>
I have yet to see a DIY for this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">
I have yet to see a DIY for this.</TD></TR></TABLE>
Matt do you have a service manual of DC5, i will try to figure out how do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jivi »</TD></TR><TR><TD CLASS="quote">
Matt do you have a service manual of DC5, i will try to figure out how do it.</TD></TR></TABLE>
No, I do not. Although, it probably could have come in handy for the swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jivi »</TD></TR><TR><TD CLASS="quote">Uhm, i got a service manual of RSX from mikey of xproductionz....
I'm thinking of another DIY
that would be fantastic. rsx cluster > em2 IMO. i've wanted to do this for some time, but i can find any information on it.
</TD></TR></TABLE>that would be fantastic. rsx cluster > em2 IMO. i've wanted to do this for some time, but i can find any information on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jivi »</TD></TR><TR><TD CLASS="quote">I'm on the process of doing it...bear with me.</TD></TR></TABLE>
any luck?
any luck?
A member named Cranny on K20.org has done a RSX Dash conversion.
I'm working on converting my interior from tan to black on my white em2. During the process I had some custom bezels made to fit the RSX cluster.
Things needed: RSX Cluster, the two harness connectors that plugs into the RSX Cluster because they are different from the em2's cluster. Pin outs from both vehicles to wire it up. You will also have to make a custom bracket to mount the cluster and a custom bezel to make it look factory. Three people have done this already and I'm almost done with mine.
The cluster shown above is the 05-06 RSX-S cluster. I still have to adjust the mounting bracket a little to lower the cluster.
i have done it on my em2...i was told that the dash frame that lies underneath the dash shell would have to be swapped out as well, which is not necessarily true. you will have to cut off about an inch from the from end of the dash that sit up against the windshield in order for it to sit in place...the air vents match up at that point...i used an electric dremel and just went to town on it...the glove compartment sits at an angle in an rsx...so our dash frame needs to be trimed about1/2 inch just in that section along the glove compartment to allow it to close...but other than that it sits just fine. i put two screws with bolts and washers on each side to raise it up just a bit and for it to hold super firm.
Jonathan_ED3
Welding / Fabrication
13
May 7, 2007 10:33 PM
surferchad122
Jan 21, 2005 03:27 PM
