itb air filters.. itb pros need help
Old Sep 21, 2007 | 07:07 PM
JDM JEFFREY's Avatar
Default itb air filters.. itb pros need help
where can I get these
I need a set for twm itbs
I have search all the topic covering the itb filter ..
Old Sep 22, 2007 | 07:43 AM
d16dcoe45's Avatar
Default Re: itb air filters.. itb pros need help (JDM JEFFREY)
I wouldn't go near those things. Its been pretty well established that filters like that really hurt airflow. Same thing with the sock type filters. Try these--or something similar--whatever width and depth would suit you:
http://www.truechoice.com/prod...C6001
You just have to drill the backing plate to match the opening of your throttle bodies. I would get the deepest filter that would fit without hitting the firewall or brake booster.
Old Sep 22, 2007 | 07:52 AM
sheekdude's Avatar
Default Re: itb air filters.. itb pros need help (d16dcoe45)
wow you're from Armonk... I haven't been up there in years. Just brings back memories... Let see if i remeber how to get there: Bx river to the Tappan Zee then get off the first exit...???
As for the itbs just get an air box... twm sells them, they work fine on my car.
Old Sep 25, 2007 | 02:43 PM
d16dcoe45's Avatar
Default Re: itb air filters.. itb pros need help (sheekdude)
From BK? I would take the BQE to the Tri-Boro, to 87 north (Deegan) to the Sprain--to Thornwood exit, then its a few local roads.....Although you could also take the Hutch, to 684 get off at exit 3 S--the "town" is right there.
What did you do in ARmonk?
There has been a few dyno sheets I have seen where it showed that the TWM airbox lost some peak power while possibly helping the midrange. I was looking into the TWM for my Weber DCOEs a while ago but I don't know if it will hurt or help....I run the Pipercross one piece foam filters I linked to before.
Old Sep 25, 2007 | 07:59 PM
98vtec's Avatar
moderator emeritus
find a post by DonF. He noted hardly any loss with the use of filters.
Old Sep 28, 2007 | 09:16 AM
onepoint6i's Avatar
Default Re: itb air filters.. itb pros need help (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">find a post by DonF. He noted hardly any loss with the use of filters.</TD></TR></TABLE>
yup about 1hp peak or something..dont quote me though...
Old Sep 28, 2007 | 11:34 AM
scmil95eg's Avatar
http://www.inglese.com/Catalog/BrochureP4.jpg
Mickey may be able to help you out with those.
I've been selling a lot of Outerwears lately, they are 25 micron and water repellant, @ $70/set of 4. I can have black, red, blue, purple, lime green and orange made up. lmk
Modified by scott@kinsler at 4:09 PM 9/28/2007
Old Sep 28, 2007 | 12:34 PM
IT GUY's Avatar
Default Re: itb air filters.. itb pros need help (scott@kinsler)
How are the outerwears on HP loss? Do you have a dyno vs. open?
I'm kinda in the market too.. TIA
Old Sep 28, 2007 | 12:53 PM
scmil95eg's Avatar
Default Re: itb air filters.. itb pros need help (IT GUY)
I haven't had a customer do a before and after dyno test so, unfortunately, I do not have any facts on HP loss. According to Outerwears, the booties they make for us "maintain peak air flow".
Old Sep 28, 2007 | 01:55 PM
d16dcoe45's Avatar
The correct filter won't really present any loss--ITG or Pipercross. The ones shown on top of the page most likely will pose a restriction.
Its not so much the filtering area, but the fact they are sitting right on the radius of the trumpets which tends to upset the air flow into the trumpets.
Old Sep 30, 2007 | 06:39 PM
pmed
rawkus
11
Nov 1, 2007 10:39 AM
Want2race
12
Dec 10, 2005 04:26 PM
blaxican05
Oct 6, 2005 08:31 PM
IVTECH
Apr 25, 2004 12:17 PM
