b16a2 into 93 si
have the motor in the car and i am just wondering if i can use a sohc v-tec obd 1 computer and dizzy if not what ecu and dizzy will work......thanks...... already searched
you can use the obd 1 dizzy and ecu but in order to use the dizzy you are going to have to swap the harnesses off the d16 you took off onto the b16. but i wouldnt recommend using the stock ecu without gettin it chipped unless you can get your hand on a p30 ecu
TravisCadello
Aug 11, 2008 09:51 AM
miataguy
Dec 22, 2002 10:14 AM
