disconnected O2 sensor and no check engine light? Sputtering as well
Old Sep 21, 2007 | 04:03 PM
ProjectDarkBlack's Avatar
Default disconnected O2 sensor and no check engine light? Sputtering as well
Hey, I have been trying to diagnose a sputtering problem with my CRX DX, I have replaced the throttle body and sensors 3 times, the map sensor once, and the distributor 3 times. I have also redone the cam timing and changed the ECU with no luck. It is getting 30+mpg and runs good above 2300, below that it is dumping fuel, there is a lot of gas inside the IM and the 1st and 2nd plugs get sooted out. I have also changed the plugs and wires. I tried to unplug the O2 sensor to see how that affected it, and there was no check engine light and nothing changed. I need to pass smog!
Old Sep 21, 2007 | 04:09 PM
thesmogman's Avatar
Default Re: disconnected O2 sensor and no check engine light? Sputtering as well (ProjectDarkBlack)
How's about the injectors? Have you ran any injector cleaner threw them.
Might have a stuck open injector or one with a terrible spray pattern.
You do have the vacuum hose connected to the FPR. Might pull that hose and see if there is gas in it. It should be dry.
A couple to check.
Old Sep 21, 2007 | 04:59 PM
Default Re: disconnected O2 sensor and no check engine light? Sputtering as well (thesmogman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">How's about the injectors? Have you ran any injector cleaner threw them.
A couple to check.</TD></TR></TABLE>
I have changed the throttle body with all attached pieces 3 times, always the same symptoms (2nd one had bad sensors). So I believe that it isn't anything attached to the items I replaced (repeadetly lol). Vacuum hoses are what I am leaning towards, that or wiring issues. This problem came in after the car had sat for 3 months (changed the HG, its solid now)
Old Sep 23, 2007 | 12:34 PM
92integraVTECgsr
Jan 21, 2008 07:48 AM
01SSAP1
Honda S2000
Sep 4, 2007 09:04 AM
civicsaremean
Jun 24, 2007 08:27 AM
JinDIESEL
Sep 17, 2004 06:33 AM
Loveless
Jun 8, 2003 10:02 AM
