radio????
all you really need to do is just establish ground and power wire
after that just trace which wires run to which speakers...take about 5 mins for all 4 speakers
screw all the aftermarket plugs and **** ive wired all my radios up like this in all my other cars and had not one problem
the only thing that could really stump you would be the power wire
ground is obvious...only black wire
as for power if other people have gone through and re-wired **** before you then it wont be the factory color....
take mine for example my power was a speaker wire with a white and green coating....juss tap each wire with your power wire on your deck till you get it to turn on
look here next time
https://honda-tech.com/zerothread/1508680
but here is what you need
http://www.installdr.com/Harnesses/HA-Wiring.pdf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spastik »</TD></TR><TR><TD CLASS="quote">look here next time
http://www.installdr.com/Harnesses/HA-Wiring.pdf</TD></TR></TABLE>
****. Trying to be Mr Helpful huh?
camogr
Apr 29, 2005 01:00 PM
tianporn
Audio / Security / Video
Jun 25, 2004 05:50 AM
