Shorter axles ??
Old Sep 21, 2007 | 12:24 PM
55superbeetle's Avatar
Default Shorter axles ??
I have a 91 si that is lowered about 2 inches with da spindles. I use it for track days so i have quite a bit of front camber. When the car sits at ride height the axle has very little movement in and out of the joints and i have a feeling they are bindind on hard compression turns. I took it apart and the axle is actually bottoming out in the inner cv cup causing a wear mark. Has anyone ran into this and does anybody make a shorter axle?
Old Sep 21, 2007 | 12:25 PM
CRX Toad's Avatar
Default Re: Shorter axles ?? (55superbeetle)
You must be more than 2 inches. I have never heard of this issue. Are you still using stock LCAs?
Old Sep 21, 2007 | 12:33 PM
Default Re: Shorter axles ?? (CRX Toad)
yep stock and i dont really know how much the front tires (205/50/15) are right at the fender lip.
b18b1ef8
Aug 29, 2010 12:21 AM
DC_Legacy
Transmission & Drivetrain
Jul 13, 2009 04:46 PM
yaya
23
Apr 3, 2006 06:24 AM
flatblack-h22
Mar 7, 2006 11:57 AM
BigBoulda
Jan 25, 2006 08:13 AM
