Ef hb front end
Would or has anyone put a type r front end on a ef hb is it worth it hard to install or what other options do I have for a front end conversion besides a type r what is the best look on a ef
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mars-EF-LS »</TD></TR><TR><TD CLASS="quote">Would or has anyone put a type r front end on a ef hb is it worth it hard to install or what other options do I have for a front end conversion besides a type r what is the best look on a ef</TD></TR></TABLE>
What is the best look on an EF? The stock front-end, or the JDM front-end. Don't bastardize another EF plz.
It's been done before, some better than others. Most are going to tell you not to do it, either politely or not so politely. In the end, you gotta do what you want and what makes you happy. A couple things to consider:
1. It's not a bolt on affair.
2. It doesn't have the same body lines/flow.
If you think you can overcome those two challenges, then go for it.
Honda_ThuGZ
Sep 23, 2007 04:55 PM
