Quick alignment question
I need to get my car aligned but have a set of rear lower control arms on the way.
Basically what im wondering is if removing the rear LCA's and putting in new ones will effect my alignment settings
They are SRR lcas if it matters
So long as the LCA's are the same length as OEM, and you don't shift the compensator arm or change the height of the suspension during your install, you should be fine.
ribal_gh
Suspension & Brakes
Mar 15, 2013 01:21 AM
