Enogh to get to 200whp?
The set up is a B16a1 w/AEM CAI, ITR throttle body, ITR Intake manifold, Toda spec c2 cams, 2ply Toda Head gasket, Toda Cam gears, 4-2-1 headers and straight exaust so far. The ECU is a JDM OBD1 PR3 un-tuned. Any suggestions of what else should be done to achieve this kinda power and to make it fairly reliable.
Let me see what the magic 8 ball says-
Chances arent good....... ok let me try again.... ( hold on while i shake it again)
Unlikely.......
Sorry bud looks like 200 is not within your grasp with that setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobby_da6 »</TD></TR><TR><TD CLASS="quote">The set up is a B16a1 w/AEM CAI, ITR throttle body, ITR Intake manifold, Toda spec c2 cams, 2ply Toda Head gasket, Toda Cam gears, 4-2-1 headers and straight exaust so far. The ECU is a JDM OBD1 PR3 un-tuned. Any suggestions of what else should be done to achieve this kinda power and to make it fairly reliable.</TD></TR></TABLE>
200? no.
tuning. FTMFW!
Modified by AccordSleeperZzZ at 4:35 PM 9/21/2007
200? no.
tuning. FTMFW!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccordSleeperZzZ »</TD></TR><TR><TD CLASS="quote">
200? no.
this is not guess your hp forum either, My guess is, not even close.
200? no.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMLS4dr200whp »</TD></TR><TR><TD CLASS="quote">pistons would be the key to ur 200whp </TD></TR></TABLE>
and better header...!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20beast978 »</TD></TR><TR><TD CLASS="quote">if you really want to hit 200whp dump that block...theres no replacement for displacement!</TD></TR></TABLE>
heres what you do, I tell everyone this
get an ls bottom end
put whatever piston setup you want in there.
put your b16 head on there with whatever cam setup you want.
get that **** tuned.
its that simple.
Im sick of seeing "I wanna make 2xx hp with my b16"
sorry its not gonna happen unless you wanna spend a decent amount of money, which in the end its cheaper to build an ls bottom end
its that simple.
Thanks for the input. i am willing to spend the extra $ and would rather keep the B16. I guess the next step is to get some CTR pistons. As for too many how can i get 200 whp from my B16 threads, sorry about that.
b16 has no torqe like the others said get a cheap ls block build it put the b16 head on there proble solved i have an ls vtec a lot better then a b16 dont waste ur time and money
Were you realy going to run Toda C's in that B16a??
https://honda-tech.com/zerosearch
^^200hp B16
notice they made that much before and after ITB's so don't take that extra cost into consideration
^^200hp B16
ITR 00_0975
Jul 24, 2003 01:24 AM
