removing front rsx bumper
Ive been looking in all the DIY threads, but I havent managed to find a detailed step by step write up on how to remove the rsx front bumper. Is there any out there?
Thanks,
David.
Thanks,
David.
Don't know if there is or not but it's not hard. There should be two screws (1 on each side) in the bumper where it connects to the fender, two screws underneath (1 on each side) that are screwed to the undertray and the rest should be those plastic pop off deals. It's easy trust me.
I know theres does like 6 or something screws on the top does are easy to remove, but ive heard so many different numbers for the bottom. I just want a step by step type manual just to make sure im removing the necessary screws so that i dont waste my time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dam2 »</TD></TR><TR><TD CLASS="quote">I know theres does like 6 or something screws on the top does are easy to remove, but ive heard so many different numbers for the bottom. I just want a step by step type manual just to make sure im removing the necessary screws so that i dont waste my time. </TD></TR></TABLE>
just work your way down from the top of the bumper. do it once and you'll never forget where the screws are.
its a link to change your emblems, but it has main points you need. just all the screw that you need to take off, and basically take the bumper off.
http://www.handa-accessories.com/rsx/08F20.pdf
310HPS2k
Mar 10, 2006 05:36 PM
