(><) damnit! i think its my master cylinder!
Old Jun 17, 2002 | 06:01 PM
CD8's Avatar
CD8
Default (><) damnit! i think its my master cylinder!
okay, so the problem i was having went away after flushing the fluid. now a similar, yet different problem has came up... from about 60mph, i get on the brakes, they grab like normal. normal stopping distance, except the brake peddle keeps moving towards the floor. not lighting quick or anything, but definatly at a steady pace. i know it shouldnt be like this. my pops suggested its the brake master cylinder on its way down the drain. im planning on getting it diagnosed tommorrow at some brake shop, i would just like to have a bit of an idea of whats going on before i go in.
any ideas?
Old Jun 17, 2002 | 06:03 PM
Conechaser's Avatar
Default Re: (><) damnit! i think its my master cylinder! (exaccord)
W/ the car off, can you pump the brake pedal and it holds pressure?
CD8's Avatar
CD8
Default Re: (><) damnit! i think its my master cylinder! (94Accord)
yes
Old Jun 17, 2002 | 06:06 PM
Martaigne's Avatar
same w/me, too... car off, pedal holds pressure
Old Jun 17, 2002 | 06:11 PM
CD8's Avatar
CD8
Default Re: (><) damnit! i think its my master cylinder! (martaigne)
94accord: do you have an idea?
Old Jun 17, 2002 | 06:23 PM
Gennady's Avatar
New User
The sympombs of a fucked mc is good normal pressure about half way down then just as your foot begins to slow, the pedal falls.
Conechaser's Avatar
Mine does it too when its REALLY hot outside. Like 90+, and im in traffic. However, at VIR I NEVER had brake fade or any problems w/ my brakes, however it was a cool 50 all weekend @ VIR. I was told that if your pedal holds pressude w/ the car off your master cylinder is fine. What brake fluid did you use again? I have Valvoline Synthetic in mine, and it still does it when its hot like stated above.
Old Jun 17, 2002 | 06:26 PM
Gennady's Avatar
New User
Maybe your MC is going too. How long has this been happening?
Old Jun 17, 2002 | 06:30 PM
Conechaser's Avatar
Default Re: (><) damnit! i think its my master cylinder! (Wont be beat)
Just started this summer when it got hot. If its below 90 it doesn't do it. Only in stop and go traffic when it is 90+ outside.
Old Jun 17, 2002 | 06:34 PM
Gennady's Avatar
New User
Could be the first signs of failure. Obviously, if it didnt happen before, and is happening now, something is screwy. I bet you dont want it to fail on you the morning of an event right? Might want to look into changing it.
Old Jun 17, 2002 | 06:38 PM
4doorH22's Avatar
Symptooms of failed master cylinder: brake pedal will occasionally sink to floor on hot days, but brakes are still mostly usable. You can't see any leakage or damage to the M/C.
Replace your M/C and with good fluid and pads your brake pedal will not sink more than 1 or 2 inches after repeated tripple digit full-on stops.
Old Jun 17, 2002 | 06:40 PM
CD8's Avatar
CD8
yeah, well im here in the desert... its 90+ at 10pm! ive never had any problems during or after an autocross event either. and that was with my old filthy fluid. now im using motul rbf600.
Old Jun 17, 2002 | 06:44 PM
Gennady's Avatar
New User
Default Re: (><) damnit! i think its my master cylinder! (4doorH22)
My MC died out of the blue. It was not close to usuable and I had drive around at 15mph all the time because I would not be able to stop at anything faster.
Old Jun 17, 2002 | 06:49 PM
Martaigne's Avatar
Eh, it hasn't been hot at all here, especially when I finished bleeding my brakes in a nice, cool garage. After I replaced the calipers and bled the brakes, the brake pedal travels a couple inches further than normal when braking, almost no pressure at all, unless the car is off.
Old Jun 17, 2002 | 07:21 PM
smokin rubber's Avatar
This is what causes failure. The filth eats the seals and eventually they fail.
My brake master cyl failed a couple years ago, it was a scary time. One week the brakes were fine, the next I had to pump the pedal like crazy to stop the car. I dont know if it help pedal pressure with the car off though.
Old Jun 17, 2002 | 07:24 PM
CD8's Avatar
CD8
Default Re: (><) damnit! i think its my master cylinder! (smokin rubber)
okay! i just ordered me a new brake m/c from http://www.manhonda.com (manchester honda). i hope they send it right away. good price too! about 84 bux shipped. thanks for all the help guys, ill definatly update you as to weather or not this fixes it. although, from what you all are explaining, id be suprised if it were anything else.
Old Jun 17, 2002 | 07:34 PM
Conechaser's Avatar
Guess i might as well and go ahead and order one as well, that and a fuel pump.
Old Jun 17, 2002 | 07:37 PM
Conechaser's Avatar
Hrm, when i was inquiring about a M/C at the parts store the other day, they had a differ model for cars w/ rear disc brakes, rear drum brakes, or if the car has ABS or not. That site lists the same one for all makes/models.
Old Jun 17, 2002 | 07:40 PM
CD8's Avatar
CD8
yeah, i noticed that too. when you fill out the ordering info, they have you give them your exact vehicle information. in their words "to ensure you get the correct part." so im guessing thats how they determine which m/c to send me. it better be right!
Old Jun 17, 2002 | 07:42 PM
I have bought a bunch of chit from them and it all fit and it all still works.
Old Jun 17, 2002 | 07:45 PM
Conechaser's Avatar
Cool deal, I just thought it was odd, because the price for the M/C for rear drums no ABS and the one for rear discs w/ ABS was VERY different at the parts store. I believe the 1st one was like $90, the latter $240.
Old Jun 17, 2002 | 07:55 PM
Conechaser's Avatar
Man, owning a high mileage car gets expensive real quick. I just replaced my clutch master cylinder and slave cylinder, now i have to replace my Master Cylinder. Went and got a fuel filter, i need to get a new clutch (170+k miles on the STOCK clutch w/ LOTS of racing on it). *sigh*
Old Jun 17, 2002 | 07:59 PM
either get rid of it quick or your in trouble,
Old Jun 17, 2002 | 08:00 PM
Gennady's Avatar
New User
Just replaced tie rod, wheel bearing, brakes, need new power window regulator. Boo whoo!
Old Jun 17, 2002 | 08:11 PM
Conechaser's Avatar
I've needed a power windor regulator for about 2yrs now, just never got one.
My rear main seal is busted. I don't want to fix this, since i am planning on doing a motorswap this winter.
I wish i could sell this car, but it would be WAY to big of a hassle, besides someone has to show everyone that Accords CAN be competitive. 4DoorH22 can attest to how well i did @ VIR w/ my el-cheapo susp.
