quick question
i need to change my oil...what kind of oil should i use? is it bad if i let my brother in law change it for me at his work...he works at a toyota dealership so they'l prob use some wack oil? what kind is da best?
it all depends what you want..
i don't like synthetitc because later down the road if you go boost synthetic breaks down to easy and faster then regular oil and once you go synthetic you can't go backwards from synthetic back to normal oil.
i use castrol gtx and a higher weighted oil like 10w instead of 5w.
10W and 5W 30 have the exact same protection as each other except you will have easier start ups with 5W. If you want thicker oil use 5W 40. K series seems to love to burn mobil 1 oil. Right now I am using Greddy 5W30 oil. It works great, doesn't use a drop.
They do, 5W 40 is made for turbo applications, 5W 60 is for high hoarse power applications. 5W-30 (vtec and high reving applications) is what they recomend from the factory and I have no issues running it even with the turbo.
let me rephrase this so i didn't confuse anyone because the way i said it. I use 10w-30 because it does not "thin" faster then 5w-30 not the viscosity break down as you said they are the same. Just like turbo'd cars a lot of people will use 20w-30 or 40 (can't remember, i just remember it has red cap) so it doesn't "thin" faster if you put 5w or 10w-30 and come out like pea soup.
Modified by risktypeS at 10:42 AM 9/23/2007
My daily driver 97 civic was broken in on dino oil then switched to mobil1 until 130k miles. I switched back 40k miles ago and have no leaks or oil usage. Ever see some civics with the entire block/header is covered in motor oil? Well mine isnt one of those.........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97civicdx »</TD></TR><TR><TD CLASS="quote">Ever see some civics with the... header is covered in motor oil? </TD></TR></TABLE>
Heh, no.
Heh, no.
svhiker
Aug 4, 2017 03:19 PM
