civic guage cluster
Old Sep 21, 2007 | 07:35 AM
nate24740's Avatar
Default civic guage cluster
is it possible to use an 05 civic gauge cluster on a crx. or is the wire to different between the two. i know is obd0 and the other obd2 so will that matter.
Old Sep 21, 2007 | 11:40 AM
GreenBean's Avatar
Default Re: civic guage cluster (nate24740)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate24740 &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible to use an 05 civic gauge cluster on a crx. or is the wire to different between the two. I know it's obd0 and the other obd2 so will that matter.</TD></TR></TABLE>
It's no so much the OBD thing you have, it's the way the guages are read by the ecu....A lot of newer cars get their readings through the ecu now, if you google it there might be somebody who has done it. Or check some of the companies that re-wire plugs for harness changes.
exsinnovation
13
Jun 13, 2006 12:23 AM
93b16CivicSi
Aug 12, 2005 06:51 PM
fast90hatch
Dec 19, 2004 07:23 AM
CRXB16PSI10
Aug 14, 2004 08:55 PM
