Fuel Rail & injector question?
Old Sep 21, 2007 | 04:05 AM
jdmludeaz's Avatar
Default Fuel Rail & injector question?
Is the AEM H22 fuel rail compatibly with the F20B. I did some searching already but was unable to find more information about combatlitily issues. Also what fuel injectors do you recommend for a N/A setup?
Old Sep 21, 2007 | 01:21 PM
MLBZ521's Avatar
Default Re: Fuel Rail & injector question? (jdmludeaz)
I don't see why the Fuel Rail wouldn't work..
The Injectors depend on how built the engine is going to be.. If it's stock, stock injectors will be fine. How are you building the engine N/A?
Old Sep 22, 2007 | 12:06 AM
jdmludeaz's Avatar
Default Re: Fuel Rail & injector question? (MLBZ521)
As of right now I plan on staying with stock internals just cause its hard to find parts for the F20B. Im using a p28 hondata just wanted to increase fuel flow.
Old Apr 13, 2008 | 09:20 AM
JDM R Cooker's Avatar
If get like a 440cc or higher do I need a fuel rail ? I have 5th gen 2001. Planning for turbo set-up.
Old Apr 13, 2008 | 12:52 PM
98vtec's Avatar
moderator emeritus
Default Re: Fuel Rail & injector question? (JDM R Cooker)
you dont need a fuel rail.
b17integra
Apr 13, 2005 10:28 PM
Shadow Templar
Jan 30, 2004 08:25 PM
Type-ARR
Feb 28, 2002 01:41 AM
