ITR suspension
You don't need the front lower control arms. Maybe some extra bolts if you break any, but I doubt that will happen since your car must be a 2000. The only things you need are the three things stated above.
How much did it cost you on the type r suspesion on your gsr ???
is there any part that is not just a easy bolt on that would require modifications ??
ok here is my shopping list
52441-ST7-R01 SPRING, RR. x 2
52611-ST7-R01 SHOCK ABSORBER UNIT, RR x 2
51606-ST7-R01 SHOCK ABSORBER UNIT, L. FR x 1
51605-ST7-R01 SHOCK ABSORBER UNIT, R. FR x 1
51401-ST7-R01 SPRING, FR x 2
52350-ST7-R00 ARM, R. RR. (LOWER) x 1
52360-ST7-R00 ARM, L. RR. (LOWER) x 1
plus misc bolts and gaskets
is there anything major i'm missing it's pretty expensive nearly $1000 already
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frstwhtgsr2000 »</TD></TR><TR><TD CLASS="quote">How much did it cost you on the type r suspesion on your gsr ???
do not buy that stuff from the dealship! if you are going to spend 1000 then you could get yourself a nice set of aftermarket coilovers that are better than the ITR components.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman »</TD></TR><TR><TD CLASS="quote">
do not buy that stuff from the dealship! if you are going to spend 1000 then you could get yourself a nice set of aftermarket coilovers that are better than the ITR components.</TD></TR></TABLE>
Yea thats insane. Just get a used set off an itr, I got everything for $180 and it only had 40k miles on it.
2000, 51401st7r01, 51605st7r01, 52350st7r00, 52441st7r01, 52611st7r01, arm, botls, control, gsr, integra, itr, lover, shock, suspension
