How do I change the miles on my cluster?!?
So I picked up a ITR Cluster. And the Cluster says 18,xxx miles and my car has about 62! I want to change it but I can't take off the red needle!!!!! I don't want to break it off cause USDM ITR Cluster are hard to come by... Can anyone give me a 'How Too'' PLEASE!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0hboitony »</TD></TR><TR><TD CLASS="quote">So I picked up a ITR Cluster. And the Cluster says 18,xxx miles and my car has about 62! I want to change it but I can't take off the red needle!!!!! I don't want to break it off cause USDM ITR Cluster are hard to come by... Can anyone give me a 'How Too'' PLEASE!!! </TD></TR></TABLE>
Indeed. They ARE hard to come by. How did you aquire it?
As far as I know, all modern clusters are tamper proof to make sure that public and private sellers of automobiles don't pull fast ones over on other buyers by rolling the odometer. You can try, but I'm sure you'll end up braking it.
I remeber seeing this this on a How To on Honda Tech! But I can't find it cause I don't know whats it called! I need some more info cause I don't want to break a 250 dollar cluster! No help at all??? No link? Must be a way some how...
with my old subaru mechanical cluster I just used a drill to spin the speed sensor really fast for a wile until the milage matched lol. sorta ghetto but if u run out of options.
I've heard of dealerships being able to calibrate clusters but that might just be with digital
I saw, sometime back, not on this site, a few multimeters hooked up in sequence to provide the necessary 5 volt pulses that spinning the VSS would produce.
But yeah, these only go forward, you would have to take it apart and break it to go backwards.
heres the thread.. but i dont think the pics are workin anymore
https://honda-tech.com/zerothread?id=837111
taking it to the dealer actually doesnt sound like a bad idea, just ask them if they can roll the miles foward to match your cars current
You will probably have difficulty locating any useful threads here, mainly because of the potential for the information being used dishonestly to defraud someone. You should be able to contact your local DMV and properly document the cluster replacement so there are no issues as far as the title or registration are concerned.
Got pictures? LMK!!! I dont know how to PM on here and stuff... New on here.. just email me
ohboitony85@yahoo.com LMK!
you don't have to 'break it' to change them back. It's very easy to do if you follow that thread that was posted. These clusters aren't very high tech, there is no big secret to doing it. Follow that thread the best u can without the pics, and you'll be able to roll the #'s with your fingers, pm me if u need help.
I think it is... BUT.............. Im not doing this to LOWER my miles... Im doing this to keep my miles in the Correct Spot! And I wanna add JDM Yellow needles aswell... I had a JDM Cluster... Once I find out how to take them off... Imma switch all the Red to Yellow...
I installed a jdm itr cluster into my gsr. I wanted my odo from my gsr to be installed into my jdm cluster so I can resume proper mileage count.
So I swapped the odometers out.
I don't have pictures so ill try my best to explain.
A method I used to take the needle off was by using 2 dinner spoons. I forced the tip of the spoons on 9 and 3 o'clock then gently proceeded to lift the needle by pressing down on the spoons simultaneously. should pop right off with ease.
calibrating the needle wasn't so easy. someone might have a better and more accurate way of doing this. but this was my method.
I wired the cluster without the clear plastic shield and screwed it down in place. Turned the key to the ON position and installed the needle to the best of my ability. remember that the needle will be resting on that plastic pin @ 0mph
But ill see wassup! Thank you again people!
