91 integra swap q's
Old Sep 20, 2007 | 10:10 PM
caliboy08's Avatar
Default 91 integra swap q's
hi, im new but i've got a few questions.. i've got a 91 integra 5spd that im about to do a b16a headswap on... what ecu and swap harness am i supposed to use? any difference on distributors? and am i needing to keep my resistor block or not... i've heard many different things, just trying to get my facts straight before i attempt this... thanks for any help at all....
Old Sep 20, 2007 | 10:13 PM
DC209's Avatar
Default Re: 91 integra swap q's (caliboy08)
i have an LS V and you will need an obd1 P28 i used the skunk 2 jumper harness and it work great and yes you will need a B16 or gsr distributor oh by the way get the golden eagle kit with the sandwhich plate a dowel pins makes it much easier
Old Sep 20, 2007 | 10:26 PM
caliboy08's Avatar
Default Re: 91 integra swap q's (DC209)
i already have the golden eagle kit... but thanks for the heads up.. i was told to get this by some people at school... so can i leave the resistor block in the car? or not.....
Old Sep 20, 2007 | 10:43 PM
DB1_559's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caliboy08 &raquo;</TD></TR><TR><TD CLASS="quote">i already have the golden eagle kit... but thanks for the heads up.. i was told to get this by some people at school... so can i leave the resistor block in the car? or not.....</TD></TR></TABLE>
i think you are talking bout the injectors resistor unit you can,if you plan on running ur obd-0 injectors but if u swap it to obd-1 you wont need it cause one is peak and hold other is saturated as in ecu i suppose any obd-1 vtec ecu or you could buy the b16 obd-0 ecu idk
Old Sep 20, 2007 | 11:13 PM
caliboy08's Avatar
Default Re: 91 integra swap q's (DB1_559)
so if i use the obd1 ecu(p28) i can stay with obd0 injectors if i use the resistor block... and if i choose to go obd1 injectors off a newer car i can bypass the resistor block? let me know if i'm understanding this correctly..
Old Sep 21, 2007 | 12:58 AM
DB1_559's Avatar
[QUOTE=caliboy08]so if i use the obd1 ecu(p28) i can stay with obd0 injectors if i use the resistor block... and if i choose to go obd1 injectors off a newer car i can bypass the resistor block? let me know if i'm understanding this correctly..
yes and yes
Old Sep 22, 2007 | 11:20 PM
caliboy08's Avatar
is there anybody thats done this swap? if so, what jumoer harness did you use and part #s please... thanks in advance..
i went to skunk2 and they have one for 92-95 integs, and Rywire.com but am not sure of the quality in those...
Old Sep 23, 2007 | 01:17 PM
DB1_559's Avatar
look for a obd-0 to obd-1 coversion harness
zombie408
Aug 6, 2018 05:36 PM
tooslohatch
47
Feb 15, 2009 03:07 PM
NachoEF9
Jan 21, 2008 05:44 PM
IntegraType-R
Jan 30, 2007 08:03 PM
