91 SI Gauge Cluster?
Old Sep 20, 2007 | 08:19 PM
ilovemyd16's Avatar
Default 91 SI Gauge Cluster?
I bought a 91 SI Gauge cluster to go into my 90 civic hatch (no tach). I haven't even put it in yet so I don't even know if it works. I know that it plugs right up but I would like to know if all my gauges and tach will work or will i need to do anything special?
Old Sep 20, 2007 | 08:25 PM
Ermil's Avatar
Default Re: 91 SI Gauge Cluster? (ilovemyd16)
Yes
Old Sep 20, 2007 | 08:32 PM
ilovemyd16's Avatar
So your saying I won't have to run a wire to the ignition for the tach it will work?
Old Sep 20, 2007 | 09:09 PM
garageEF's Avatar
Default Re: (ilovemyd16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovemyd16 &raquo;</TD></TR><TR><TD CLASS="quote">So your saying I won't have to run a wire to the ignition for the tach it will work?</TD></TR></TABLE>
it will work fine
Old Sep 21, 2007 | 11:44 AM
GreenBean's Avatar
Yours and all Civics have an igniter in the distributor housing, it has a tach feed, it's the fourth terminal or closest to you (blue wire) if you remove the cap. It will work...Mine didn't when I installed my cluster then I found out the terminal had slipped off when I changed my rotor button and cap.
ajason24
Honda Motorcycles
Mar 9, 2009 05:54 PM
anht
Sep 10, 2005 05:45 PM
PETEROCK1
Jul 1, 2005 06:16 AM
EF'IN NUTS
Mar 27, 2004 08:53 AM
rody084
12
Dec 30, 2003 08:52 AM
