D16A1 - How to prime the oil pump or can I get by without doing this?
Old Sep 20, 2007 | 06:44 PM
AK77's Avatar
Default D16A1 - How to prime the oil pump or can I get by without doing this?
Old Sep 20, 2007 | 06:49 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: D16A1 - How to prime the oil pump or can I get by without doing this? (AK77)
Not a billion percent sure, but IIRC you remove spark plugs, disconnect coil, unplug injectors and crank motor until oil pressure light goes out.
Old Sep 20, 2007 | 07:26 PM
AK77's Avatar
So what you are saying is that I don't have to remove oil pump to prime it. I can put everything together, fill all fluids, including oil, then either by hand rotate crank or just remove spark plugs and crank it to get oil through the pump?
Old Sep 21, 2007 | 12:29 PM
95 integra's Avatar
Generally I let the starter do the turning....it takes awhile for it to build pressure.
wickedplastikman
Feb 20, 2009 02:40 PM
GoldLudeRay
Feb 10, 2009 07:04 AM
sleepyhatch00
Sep 2, 2005 01:35 PM
Mefain
May 16, 2003 09:02 AM
PyroVTEC
Aug 19, 2002 08:12 AM
