My Nox is still high!
my nox is still high and i changed the cat, put timing back to zero, new 02 sensors, and still the nox is like 20 points higher. anyone have any suggestions also how do you get rid the trial thing below my screen name? I HAVE STOCK Z6 motor
they still got egr valves? if they do damn i dont know..haha but had all vcacuum lines checked and no leaks? could it be the injectors?
high nox is caused by high cylinder temp. usaully a bad egr valve, but there are some other thing like dirty coolant not cooling the cylinders properly, running lean for some reason like coolant temp sensor sending impropper signal to ecu, spark plugs etc.
stackz
Other Make Vehicles
Dec 9, 2010 04:18 PM
SRd240sx
Jan 10, 2006 04:53 PM
