dc5 recaros fit ek?
Old Sep 20, 2007 | 01:44 PM
jdmmanek's Avatar
Default dc5 recaros fit ek?
Will dc5 recaros fit inside a ek. Also whats the asking price for a mint set?
Old Sep 20, 2007 | 01:47 PM
tx_ej8_49's Avatar
Default Re: dc5 recaros fit ek? (jdmmanek)
1. Not sure.
2. Hondamarketplace.com<-Should be able to find a set there.
Old Sep 20, 2007 | 01:48 PM
97Ej6mike's Avatar
Not sure on the price, but yes they can be put into any 92-00 civic, simply by using your year civics' seat rails. Some modifications are required in order to make them fit to the rails ( can be done outside of car) but once that is done, they will just go in.
Old Sep 20, 2007 | 01:56 PM
Dante Civic's Avatar
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">Not sure on the price, but yes they can be put into any 92-00 civic, simply by using your year civics' seat rails. Some modifications are required in order to make them fit to the rails ( can be done outside of car) but once that is done, they will just go in.</TD></TR></TABLE>
x2
Old Sep 20, 2007 | 02:12 PM
PhrequenC's Avatar
not trying to hi-jack the thead, but what will haev to be done to get ep3 stocks in a ej8
Old Sep 20, 2007 | 02:24 PM
01_CLtypeS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmmanek &raquo;</TD></TR><TR><TD CLASS="quote">Will dc5 recaros fit inside a ek. Also whats the asking price for a mint set?</TD></TR></TABLE>
$1500...
http://jrautoparts.com/misc7.htm bottom of the page
Old Sep 20, 2007 | 02:33 PM
JKov240's Avatar
Default Re: dc5 recaros fit ek? (PhrequenC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhrequenC &raquo;</TD></TR><TR><TD CLASS="quote">not trying to hi-jack the thead, but what will haev to be done to get ep3 stocks in a ej8 </TD></TR></TABLE>
(This is in an EG hatchback...but there shouldn't be too much difference)
Either custom rails or modifying the EP3 rails. I modified the EP3 rails...the rear 2 bolts line up (with a little bit of force , but they do line up with the stock holes), the front 2 are a different story.
Me and my buddy cut the front brackets off, then bolted the brackets to the floor. I then took a hammer (quite literally) and beat them down flat so that they'd line up with the seat rails. He then tack welded them...we took them out, and welded them all the way around.
People say that the welds don't look safe...in reality, the welds are stronger than the metal pieces you weld together.
Old Sep 20, 2007 | 05:19 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">simply by using your year civics' seat rails. Some modifications are required in order to make them fit to the rails ( can be done outside of car) but once that is done, they will just go in.</TD></TR></TABLE>
This is incorrect. The Recaros don't use the stock rails.
To OP, you need OEM Recaros rails from a 96-00 Civic Type-R or Vision one-touch sliders for a 96-00 Civic. I bought a mint set of red DC5R Recaros for like $900
97civic123
Audio / Security / Video
Jun 24, 2008 09:59 AM
Ed03Feng
Jun 14, 2008 05:24 AM
jdmmanek
Sep 20, 2007 12:35 AM
fastfu
Sep 1, 2005 05:18 PM
RedGSR
Feb 9, 2005 08:49 PM
