? about installing MSD blaster SS external coil
Old Sep 20, 2007 | 12:53 PM
92redhatch's Avatar
Default ? about installing MSD blaster SS external coil
I made an aluminum bracket for it and i wanted to know if i could mount it directly on top of the aluminum bracket( just incase it would short circuit). im also using NAPA screws ( i dont have the msd screws) to hold it onto my bracket. I heard something about using bolts with rubber so that the external coil wouldn't short circuit.
Before i started the car i wanted to make sure that it would be fine. Any info will be appreciated.
thanx
Old Sep 20, 2007 | 11:13 PM
Pro-Am 1934's Avatar
Default Re: ? about installing MSD blaster SS external coil (92redhatch)
The rubber spacers that come with the MSD products are used more as "vibration dampers." You do not have to use them with the coils, as they are housed in plastic. I would just order a set from MSD to have and use. Hell if you call the tech department they may just send you a set.
Jason
Old Sep 21, 2007 | 09:12 AM
92redhatch's Avatar
i have a few of the msd rubber "vibration dampners"
neo_
Jan 15, 2009 08:06 PM
92redhatch
Sep 20, 2007 06:20 PM
flyrice
Jul 20, 2004 08:57 PM
