Custom B16 piston on an LS / B18 rod?
Old Sep 20, 2007 | 11:33 AM
tunedek's Avatar
Default Custom B16 piston on an LS / B18 rod?
Block: B16
Crank: B16
Rod: LS
Piston: Custom B16 ... ?
That is the setup I wish to build. Why a bunch will immediately ask - 1.78 rod:stroke ratio.
I know this has been done several times. What I don't know is where I can buy the piston for this or what I would need my machine shop to do to the shelf piston I would buy and then modify.
I tried searching but came up empty on results answering my questions. I used search terms such as: b16 piston b18 rod; b16/b18.
Thanks in advance for you help.
Old Oct 10, 2007 | 10:54 PM
_oemek_'s Avatar
Default Re: Custom B16 piston on an LS / B18 rod? (tunedek)
try calling up CP pistons.
Old Oct 11, 2007 | 12:29 AM
ExospeedAMcrx's Avatar
we do custom pistons all the time. all ours are done by Arias. pm me if you need help.
sowellman88011
20
Oct 18, 2012 02:36 PM
teefunk01
May 12, 2005 02:29 PM
HmgLauj69
Jul 1, 2003 12:37 AM
