B18C burning oil
Old Sep 20, 2007 | 11:06 AM
Arvid_'s Avatar
Default B18C burning oil
Hello everybody,
I've recently done a swap in my CRX EE8 (european B16 CRX). I put in a JDM B18C 98 spec engine (200hp 11:1cr). It wasn't used for about one year. After changing the neccesary parts (timing belt, tensioner, water pump, spark plugs, oil etc..) it was tuned with bre and runs a bit rich. With the stock B16 intake it made 196 peak hp with a nice curve so looks prety good for a stock engine. The problem is it burns quite alot of oil (when accelerating with trhrottle wide open and changing gears). I can even see blue smoke behind the car sometimes and smell the burnt oil. It's alsoclear when I check the oil dip stick from time to time.
I've done a compression test (engine warm, throttle wide open, good gauge). I've done it twice and the results where 243,245,235,243PSI for no. 1,2,3,4 cyl. (I've also done it with a different gauge but it was scaled only to 220 psi and the readings went out the scale for each cyl). Doesn't look too bad I think. I don't think it's the valve seals, wchich are causing so much oil burning. Is it possible that the piston oil rings are worn and the piston sealing rings allright. What else could I chceck before I take down the cyl. head. Could it be affected due to the long time the engine wasn't used? Any tips??
Old Sep 20, 2007 | 06:16 PM
sinister6's Avatar
If it burns oil then its far away from good.
B18 is suppose to burn oil, it just depends on how much it burned. for example lost a litre after runing a full tank of gas is not normal.
Old Sep 21, 2007 | 06:24 AM
McDonagh's Avatar
Default Re: B18C burning oil (Arvid_)
Put a can of Restore in it, see what happens.
Old Sep 21, 2007 | 11:10 AM
Arvid_'s Avatar
Default Re: (sinister6)
i ment the compression test wasn't too bad,
Old Sep 21, 2007 | 11:20 AM
Jasper_db1's Avatar
I have a similar situation with my Built B17 and believe that the problem is in the head.
Old Sep 21, 2007 | 03:00 PM
mar778c's Avatar
Community Builder
Community Influencer
Unfortunately, you've got a ring seal problem.
Old Sep 22, 2007 | 06:15 AM
ctr power's Avatar
Default Re: B18C burning oil (mar778c)
mr788 is right seems to be rings problem blue smoke indicates oil burning
Old Sep 22, 2007 | 08:14 AM
standbackimapro's Avatar
Rings isnt the only thing that causes oil to burn.
Do a compression test, whats a b18c supose to be, like 270 i think
thattll show the condition of your rings, do a leak down test and see how your valve seals are
Old Sep 22, 2007 | 11:35 AM
Arvid_'s Avatar
Default Re: (standbackimapro)
270 is nominal, straight out of factory, anyway I guess there's no other way than take it apart
Old Sep 22, 2007 | 11:54 AM
2ltrtodd's Avatar
* B A N N E D *
Default Re: (Arvid_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arvid_ &raquo;</TD></TR><TR><TD CLASS="quote">
270 is nominal, straight out of factory</TD></TR></TABLE>
270psi is ****** high. my 13.5:1 85mm gsr makes only just under 300psi and thats brand new motor.
my jdm gsr 10.6:1 did 200-201-202-200 across 1-2-3-4.....and it only had 25,000kilometres on it. (15,500 miles)
anyways if its burning on accel then its probly your rings im guessin
Old Sep 22, 2007 | 11:55 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: (2ltrtodd)
My rings were out too
Old Sep 24, 2007 | 04:23 PM
b18c1ej8's Avatar
Default Re: (5_Lug_B)
sounds like some bad valve seals man
delsol-101
Sep 4, 2014 09:50 AM
Team PHATBOYZ
Feb 29, 2008 02:22 PM
andrewbolton
May 4, 2005 07:24 AM
B18Ccivic
Feb 2, 2003 05:25 PM
Petah
Mar 11, 2002 11:04 AM
